| Cleaning the black bits! Hi. Can anyone tell me how to clean the black trim that goes around the car i.e above the door. (and forms part of the windscreen structure too) It's like a felt / plastic material and usually ends up white after using polish on the bodywork. Also, the black soundproofing / sealent around the sunroof - and tips ideas please?? Thanks. |
| yeah but cos the area im treating is so thin i.e you cannot spray it directly on how do you apply it without it going all over the newly polished bodywork ? And if you put it on before polishing then you get the white marks! Arghhh! |
| the professionals use a kind of masking tape to tape over the plastic areas when polishing the metal to ensure that polish doesnt go on the plastic resulting in white faded bits. n vice versa you can mask the metal/painted areas to treat the plastic without getting the spray/gel on the paintwork ![]() and yes this is a Bugatti Veyron m o n k e y : n u t s Last edited by MINIAC; Apr 15th, 2007 at 08:51 PM. Reason: Make image clickable thumbnail |
| I use the autoglym bumper care on the black bits at the bottom of the car. It's a green gel and works really well. I haven't used anything on the trim around the top yet as I've got a convetible so there isn't much to do. I do use masking tape to prevent the white marks though. I've got some extra felxible stuff from B&Q, it only takes a few mins to apply and saves getting any marks. |
| Mask up with 3M 3434 tape to prevent polish / wax going where it is unwanted! I dont have a sunroof on my MC but im guessing the black rubber around the sunroof is the same as around the windscreen / windows? If so then you need this (Einszett Gummi Pfledge) Einszett Rubber Protection "Gummi Pflege" Einzsett do some good products for trim care! Dont use back to black as it is an extremely bad product. Washes off after a quick shower of rain! I also like Chemical Guys New Look Trim Gel for the plastic trim, and Poorboys Trim Restorer Hope this helps! P.S. To whoever posted the pic of the Veyron... That was some detail wasnt it! Looked amazing once it was finished! P.P.S. To remove the white stains on the plastic use Smooth Peanut Butter |
| What do you use on your black bits? | JAMIE1131 | Maintenance & MINI Care | 27 | May 13th, 2007 01:31 PM |
| Cleaning my new black mini | applebed | Maintenance & MINI Care | 4 | Apr 11th, 2005 08:46 PM |
| Black Trim cleaning search | TURB CAB | Maintenance & MINI Care | 7 | Dec 12th, 2004 12:16 PM |
| keeping the black bits black | Goonery | First Generation MINI Exterior | 7 | Aug 8th, 2004 01:25 PM |
| Keeping Black Plasticky Exterior Bits Black | lotoole3 | Maintenance & MINI Care | 3 | Sep 13th, 2002 10:39 AM |
