| A/C compressor wiring recharge I am troubleshooting my A/C on my '02 MCS. I want to manually turn on the A/C compressor (It is not turning on automatically ). I found the relay in the engine compartment fuse box -- Can I bypass the relay contacts and turn on the compressor momentarily? The wire harness to the compressor is not accessible to put 12 volts there. Thanks -- Dave |
| Tags: compressor, relay, wire |
| Should compressor etc be standard? | NurseJAG | First Generation MINI Cooper S | 6 | Nov 14th, 2006 08:28 AM |
| A/C Recharge / R134a Charge Specs | IanW | First Generation Faults & Fixes | 4 | Sep 24th, 2006 08:06 PM |
| This spring compressor? | Bootsy | First Generation MINI Suspension | 5 | Dec 10th, 2005 12:39 PM |
| Air Compressor | wibbly | Wheels, Tyres & Brakes | 3 | Aug 18th, 2004 11:02 AM |
| K&N filter Recharge Kit on Alta Cold Air Intake? | WENZOR007 | First Generation MINI Cooper S | 0 | Apr 25th, 2004 11:46 AM |
