1st Generation Battery Replacement Having some questions about whether the vent tube could be fitted to an Interstate MT-47 battery, I took a trip down to the Interstate Battery Distributor today. I ended up getting a VW/Audi OEM replacement battery which is a "perfect" match dimension-wise (242mm x 175mm x 190mm) to the stock battery and has the vent tube hole in the same place: The battery is made by VARTA a European subsidiary of Johnson Controls Inc. The original battery labels were removed and replaced with a generic ones because the battery is really only meant to be sold to VW/Audi dealerships. The battery is rated at 540 CCA and 61 Ah and you can see where it fits in the hierarchy of VARTA aftermarket batteries recommended for the MINI: Warranty: 2 year free replacement / 75 month pro-rated thereafter $111.44 installed Last edited by MINIAC; Aug 29th, 2007 at 10:11 PM. |
| The Following 2 Users Say Thank You to MINIAC For This Useful Post: | ||
| I wonder where I can find one of these in my local area.... South Florida (33463). Anyone know of a website I can goto to put in my zipcode and find a dealer/distributor? ![]() |
| Hello MINIAC. Do you happen to know if the Interstate MT-47 will fit into a 2005 Mini 'S'? The OEM battery PART NUMBER ON THE BATTERS IS ....S 61 21 6 920 804. By the by, if I am doing something incorrect about placing this request in the wrong place on this site, please don't hesitate to correct me Thanks Steven |
| Replacement Battery For First Gen Mini 's' hello MINIAC, I went to the Interstate Web Site. I punched in the number 563 400 061 3162 which is the part number on your post/thread that appllies to the generic Interstate battery you have in your car. Just what I need. But when I get to the site I find interstate Megatron car batteries with that same part number. Where can i find this battery? I live in central California. Thanks EvenSteven Steven H Gellis Gellishoward@aol.com |
| Click The battery I got was a VARTA battery which Interstate distributes to VW/Audi dealerships. If you go into a Distributor (rather than a Dealer) they should be able to sort things out. |
| Tags: battery, replacement |
| Best Battery Replacement? | JG.26 | Maintenance & MINI Care | 3 | Jun 16th, 2008 12:22 AM |
| Looking for a 1st Gen replacement battery in SF Bay Area? | MINIAC | Northern California Region | 0 | Aug 23rd, 2007 10:32 PM |
| Chronology of 1st Generation MINI Changes | MINIAC | USA | 16 | Aug 16th, 2006 08:35 PM |
| Battery Replacement | prs | First Generation Faults & Fixes | 11 | Aug 11th, 2006 05:13 PM |
