FOMSPORT
Old Sep 7th, 2007, 03:49 PM   #1
rec
Not a happy bunny.
rec's Avatar
Local Time: 01:15 AM
Send a message via MSN to rec
Using Clay Bar ?
Hey all,
n00b question here... how do you use a clay bar ?
I was lookin at these: Zymol Zymol Lehm-Klay Bar 2 from Monza Car Care with Zymol Zymol Lehm-Lube from Monza Car Care
but how and when do you use it ?
England Male View rec's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Sep 7th, 2007, 03:53 PM   #2 (permalink)
minisoopercooper
Some have THICK skins!!!!
minisoopercooper's Avatar
Send a message via MSN to minisoopercooper Send a message via Skype™ to minisoopercooper
I have used the mequiars quick clay bar system - available from halfords for around £15. Full instructions on the pack.
I wouldn't do it too often as like polishing you will remove a small layer each time. Basically you clean the car as well as possible then spray the surface with the detailing spray supplied. Then simply rub the clay bar in horizontal lines panel by panel. this removes most scratches and contaminants. I then scratch x'd the car and a final polish - it looked amazing.
Well worth the efort
↑↑↑ - Click me for the event of the year. - ↑↑↑
United Kingdom Visit my Blog at the Motorcade Male View minisoopercooper's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 7th, 2007, 03:54 PM   #3 (permalink)
Paul
Trained Monkey
Paul's Avatar
I have meguiars quick clay. The clay is soft and malleable and you have a spray to dampen the surface. It's a bit like using blu-tac to clean marks (usually left by blu-tac) from your wall.
Old Sep 7th, 2007, 04:50 PM   #4 (permalink)
PmP
GP 0380
PmP's Avatar
Zymol clay bar is 3 times the size of the meguiars clay bar and works better as it is softer.
Although if you dont keep it well lubricated it can break up.
Better still is the Sonus Green Clay bar, two bars bigger than the meguiars bars for £7, nice and soft, and comes in different grades.
Wash your car and dry it. Now feel the paint with your fingertips, does it feel like glass? Or does it feel a little rough? If the answer is rough that is bonded contaminants (tar spots, tree sap, road grime) you feel. The clay bar will remove these, and it will amaze you how the paint feels like glass after. This is the best way to remove these contaminants. And it will amaze you how much more of a shine the paint will have after.
As someone else said dont do it all the time, maybe 3 times a year. You do get abbrasive clay bars for stubborn jobs like 4X4's, but these are far less abrasive than any polishes. So it wont remove any paint or clear coat, unless you use a dirty piece of clay. Just be sure to fold the clay bar in two and use a clean side at all times. And keep the paintwork and clay well lubricated with a detailing spray or water with car shampoo added.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 7th, 2007, 04:52 PM   #5 (permalink)
PmP
GP 0380
PmP's Avatar
This is quite good for beginners, but it is quite a hard clay and not the easiest to work with.
Other reason I forgot for not doing it too often is, it takes a few hours to do a car properly. Mini's not too bad as its fairly small.
Old Sep 7th, 2007, 05:37 PM   #6 (permalink)
Paul
Trained Monkey
Paul's Avatar
I've only ever used the meguiars and I was surprised how soft it was. Softer than I expected anyway!
Old Sep 8th, 2007, 06:27 PM   #7 (permalink)
I love MINI, Laura
I don't bother with the quick detailer when claying. i use the bar while washing the car and the clean soapy water does a great job at lubricating the clay. i only do it when it feels a bit rough. Usual places get it the most. Back end, roof and below the windows are the worst.
My advise would be to break up the clay bar into workable size pieces like you would do with blue tack and when a piece gets too dirty I use that on the alloy wheels to get baked on rubbish off there. I love by clay bar and will always use it to keep my paint work as smooth and like glass as possible!
United Kingdom Female View I love MINI, Laura's Royal Grey & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 9th, 2007, 03:14 PM   #8 (permalink)
PmP
GP 0380
PmP's Avatar
As I think I said you can use water and car shampoo to lubricate the clay, but I hope you wash the loose dirt away before you clay? Only down side about using car shampoo is some shampoos dry and leave paint smeared. Quick detailer doesnt really.
It is a good idea to break it into smaller bits as said, especially as its easy to drop a bit. And that renders it useless as it will lift dirt off ground.
Use it on exterior glass also it makes a difference.
Someone mentioned meguiars being soft, try sonus green, much cheaper and its far far softer and easier worked.
Old Sep 9th, 2007, 03:48 PM   #9 (permalink)
monkeynuts
my ponies have escaped!!!
monkeynuts's Avatar
As more n more people are trying this ive posted a thread here with a guide
http://www.mini2.com/forum/maintenan...ml#post3152044
m o n k e y : n u t s
Old Sep 9th, 2007, 04:54 PM   #10 (permalink)
PmP
GP 0380
PmP's Avatar
Good one.
In fact most questions about detailing can be answered by a quick search on detailingworld.
Old Sep 23rd, 2007, 12:58 PM   #11 (permalink)
Greenscaile
I've been converted.....
I wish i had used this clay stuff before. I only used this weekend to give the car a final going over before its replaced next weekend and sold.
It had four and a half years of unseen gunk stuck to it. I all ever did was wash and wax. But WOW, what a difference. It was only after i strted with the clay bar, did I realise how much unseen grime there was.
This is going to be a permanent fixture in the valet box from now on.
I am so glad i found this site, just for this little gem.
Old Sep 23rd, 2007, 01:10 PM   #12 (permalink)
Paul
Trained Monkey
Paul's Avatar
It is a brilliant tool, and the more people use it the better people will understand the product and how to better care for their car. Which not only bodes well for current owners, but those buying second hand too.
Old Sep 23rd, 2007, 01:46 PM   #13 (permalink)
rec
Not a happy bunny.
rec's Avatar
well, i did mine yesterday and damn was it easy ! good results too
tho i must admit i did search Youtube and watch the Meg video on how to do it :P
Old Sep 23rd, 2007, 05:41 PM   #14 (permalink)
Nebdingo
ProNet:3 Gaming Community
Nebdingo's Avatar
Send a message via ICQ to Nebdingo Send a message via MSN to Nebdingo Send a message via Yahoo to Nebdingo
just keep it "lubed" up plenty!! raaa!!
England Male View Nebdingo's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 24th, 2007, 08:03 AM   #15 (permalink)
rec
Not a happy bunny.
rec's Avatar
what about storing it ? i've put it back into the little "box" that it came in, but i think it'll dry out. should i put it in a little zippy lock bag ?
Old Sep 24th, 2007, 08:34 AM   #16 (permalink)
Japper
Japper's Avatar
Claying does not take a layer of lacquer off like a polish would. Claying takes surface contaminents off only and so does not remove scratches either.
06 HB/W MCS Chilli
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Sep 24th, 2007, 08:35 AM   #17 (permalink)
I love MINI, Laura
I just put it in a plastic bag and keep it separate from other bits once its been used. Its gets a bit sticky when dry.
Old Sep 24th, 2007, 08:36 AM   #18 (permalink)
Japper
Japper's Avatar
Hi Greenscaile, have you ever seen Polished Bliss's work ?. Well worth a visit seeing as you're local.
06 HB/W MCS Chilli
Old Sep 24th, 2007, 08:57 AM   #19 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Local Time: 08:15 PM
Clayed the wifes Suby this weekend and I have to say it looks fab! Now that I have tested my skills on her car I can do it on the MINI!
FYI, that is the best that 04 Suby has looked in a few years. She has white paint and the clay really made a difference on the over all appearance.
Global Moderator
clay bar Wooly Maintenance & MINI Care 24 May 15th, 2007 10:06 PM
What maguires do i need, and what is clay bar? Lee Bradshaw Maintenance & MINI Care 26 May 27th, 2006 09:21 PM
Clay Bar SteveBrass Maintenance & MINI Care 5 May 23rd, 2005 12:34 PM
Clay Bar Use Grumbler Maintenance & MINI Care 22 Apr 30th, 2004 04:07 AM
Detailing - Clay Bar OUSOONER Maintenance & MINI Care 4 Oct 1st, 2002 11:20 AM
