Passenger door not unlocking!!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 1st, 2007, 07:19 PM
jbncoke's Avatar
Local Time: 12:13 AM
United-Kingdom Passenger door not unlocking!!!!
The passenger door in my 2003 cooper will not unlock when I press the key fob since about a week ago. The driver door and boot unlock fine. Any ideas folks?
JB
Old Oct 2nd, 2007, 09:30 PM
still learning
Local Time: 01:13 AM
Scotland Male
does it unlock with the key ok ?
have you tried your spare key fob ?
has anyone been messing about with the programming ?
sorry I can't be more help, but you need to start somewhere !!!
Old Oct 6th, 2007, 10:12 AM
I think the passenger door solanoid has gone - it's just happened to me. Part was £58 inc. VAT from local stealer, but will be getting a local mechanic to fit it to avoid stealer labour charges!
Old Oct 9th, 2007, 07:48 PM
jbncoke's Avatar
England
Oh great. that's a bit of a bummer, i've just paid out for TLCXL too! I have my car booked into a local mechanic next week to have a quick look at it. I'll keep you informed.
Old Oct 19th, 2007, 08:54 PM
Local Time: 07:13 PM
Listen to the door
Have someone push the unlock button while you have your ear or hand on the door, if you feel movement in the door then the lock has just popped of the hinge or something small. If you feel nothing than its prb the seloniod. or lock actuator, not sure of the name. Either way the door has to come apart to fix it. Gluck!
If your any good at mechanics you can always take apart the door, and check the wires going to the locking mechanism. Have someone hit the unlock button and check if the signals is there. If it is then replace the locking mechanism that sint activating, if it isn't then its either the switch or a short.
Old Oct 19th, 2007, 09:34 PM
obehave's Avatar
Mini Mod
Local Time: 08:13 PM
Locks fine though right? Just won't unlock.
If you have the feature I'm betting it doesn't autolock when taking off either.
If these are true then it's the actuator. Had mine replaced once. Needs it again.
Old Oct 22nd, 2007, 07:43 AM
Mini2 Regular
Send a message via MSN to dh2310
United Kingdom Male View dh2310's Chili Red & Body Color 1st Gen MINI One Diesel Profile View dh2310's Classified Ads
Hi, i have a problem with my Mini One D where the passenger door does not lock or unlock.
Does anyone know if this is a programmable option or if its more likely to be the solenoid at fault?
Dan
Mini Newbie
Old Oct 26th, 2007, 12:17 PM
jbncoke's Avatar
England
I have had my cooper in for a brake fluid change at a BMW garage. They did a routine check externally and internally and picked up on my passenger door not unlocking. They reckon it's the solanoid and quoted me £185.40! They couldn't say for definite as they didn't strip down the door. I can still open it from the inside, so will put up with it for now!
Tags: , ,
Remote door unlocking problem feenster First Generation Faults & Fixes 39 Oct 10th, 2008 07:22 PM
Timing for remote unlocking of passenger door Darkstar Maintenance & MINI Care 3 Mar 22nd, 2007 11:21 PM
Passenger Door Problem? MaTTy_P First Generation Faults & Fixes 0 Sep 30th, 2005 03:56 PM
passenger door cannot be opened Gr1zzLy First Generation Faults & Fixes 3 Jul 6th, 2005 02:07 AM
Door Unlocking Indication M for Mini General Discussion 2 Jan 16th, 2003 10:25 PM
