scratch remover - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 8th, 2007, 06:15 PM
Local Time: 01:13 AM
England scratch remover
["]help people some clown has trollied me have a scratch down the door also a few stone chips have tried an autoglm product on recommendation but its not much better any ideas please[ :
Old Oct 8th, 2007, 07:07 PM
United Kingdom Male View mac2's Astro Black & Body Color 2nd Gen MINI Cooper S Profile
Try Meguiar's Scratch X
Old Oct 8th, 2007, 07:13 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
What colour is the car and can you post a pic of the scratch?
TBH Megs Scratch X is not that good of a polish either to be taking scratches out of MINI's rock solid paint.
Need something a little better, something that you wont get at halfrauds.
Old Oct 8th, 2007, 07:36 PM
alski's Avatar
dyno-mite, might not....
Local Time: 12:13 AM
England Male View alski's Classified Ads
i can confirm scratch x no good on hyper blue
carefree
Old Oct 9th, 2007, 12:08 PM
the colour is base red the scratch is about 7 inches and the depth of a thick fingernail hope this helps ta
Old Oct 9th, 2007, 12:17 PM
ScottyBoy's Avatar
Unfortuantely if its that deep then i doubt you will be able to get it out by hand, that requires a pro's hand with a a bit of wet n dry sand paper and a machine polisher, or a respray at worst.
Scott
Old Oct 9th, 2007, 12:28 PM
AndyH_MCS's Avatar
United Kingdom Male View AndyH_MCS's Electric Blue & Black 1st Gen MINI Cooper S Profile View AndyH_MCS's Classified Ads
If the scratch has gone down to the primer then it will need paint. Pro detailers will lay paint in the scratch, leave to dry, wetsand flat and machine polish the wet sanding marks out.
If its not deep then the scratch can be polished out, however, you won't have much luck by hand. As said above the Mini's paint is hard as nails. Even my Dual Action polisher struggles (Porter Cable) and i have to crack out the Makita rotary!
Stone chips are what they say on the tin. Chips into the paint work exposing the primer/metal underneath. These WILL need paint and can be done individually by the method described above
Old Oct 14th, 2007, 05:59 PM
think1's Avatar
England
so which scratch remover would you recommend for small scratches?
Old Oct 16th, 2007, 09:38 AM
Red Dwarf's Avatar
Stoke me a Clipper!
Send a message via MSN to Red Dwarf
England Male
I do use Meguires Scratch X, and it's makes things better, not perfect though. It doesn't sort out scratches in the laquer coat, least not for me.
Red Dwarf has left the room
Old Oct 16th, 2007, 02:45 PM
Nebdingo's Avatar
Send a message via ICQ to Nebdingo Send a message via MSN to Nebdingo
England Male View Nebdingo's Midnight Black & Body Color 2nd Gen MINI Cooper S Profile
if you can feel the scratch with a fingernail forget it!!
get yourself some touchup stick (the real mccoy preferably) skake well (this is important) then get yourself a number 1 and number 000 artist paintbrush.
clay the area, then using your paintbrush PATIENTLY add a layer. leave to dry for 24 hours then add another layer to build them up! (may need more than 2 layers depending on scratch/chip) remember, take your time for a better finish! then when you have just built up enough layers so that it sticks out JUST over the paintwork THEN use scratchX or a decent polish to rub down to correct level.
if you have used too much use a jcloth with thinners to remove excess paint touch up!
just remember. BE PATIENT!!!
this has always worked for me!
Last edited by Nebdingo; Oct 16th, 2007 at 02:47 PM. Reason: Spelling of a 5 year old!! tut tut!!
Clay Bar or Tar Remover Pamster Maintenance & MINI Care 9 May 3rd, 2006 07:31 AM
Lint Remover? howardpm First Generation MINI Convertible 7 Jun 22nd, 2005 05:25 AM
Road paint remover? Ginger Maintenance & MINI Care 3 Jul 30th, 2004 02:29 PM
Tar & Spot Remover............?? AidenL Maintenance & MINI Care 8 Apr 18th, 2003 04:13 PM
