Engine maintenance in OC, California I have a 2003 MINI. Two months ago the engine overheated and leaked lots of coolant. I took it immediately to Irvine MINI. They said they could not find a leak, but charged me $340 to replace the thermostat! Driving to work today it leaked again and overheated - same symptoms as before. I am told there is a crack in the radiator that will cost over $800 to repair; naturally the crack is new and not related to the previous leak. Sounds fishy to me. Don't tell me about Crevier, I've tried them many times and was also very dissappointed (several items were stolen from car, did not do all work, could not find noted problems, etc). So, I am in desparate need of an independent, qualified MINI service shop in Orange County, California. Thanks. |
| If you're an Auto Club member (or even if you're not -- you can still use the search facility), try one of their Approved Auto Repair facilities: AAA Approved Auto Repair Facilities Search I've generally had good luck. And the one time I didn't, AAA proved to be a very able ally. |
| Tags: engine maintenance, orange county |
| Is JCW maintenance more expensive than regular Cooper S maintenance? | Aminiman | First Generation MINI Cooper S | 2 | Mar 19th, 2006 11:23 AM |
| Maintenance Manuals | Choprpilot76 | Maintenance & MINI Care | 4 | Oct 1st, 2004 02:33 PM |
| Maintenance Packages... | TARYNosaurus | First Generation MINI Cooper S | 2 | May 31st, 2004 01:16 AM |
| maintenance schedule | KAMAKAZI | Maintenance & MINI Care | 1 | Sep 12th, 2002 05:57 PM |
| Attention dealers in states close to california or in california... | fjork_duf | General Discussion | 6 | May 16th, 2002 01:52 AM |
