| Tags: mini coolant leak |
| MINI2 Newbie Join Date: Oct 2007 Local Time: 07:12 PM
Offline | Bmw mini coolant leak 2005 Mini One has a coolant leak which only seems to only leak after being left overnight. There are no signs of coolant in garage but when the car is taken out onto the drive and is running it will drip for about a minute from either the rear of engine or under the bulk-head. It is definitely anti freeze as it is blue and the level is dropping. After it has lost a certain amount of fluid it seems to stop. Any ideas? |
![]() Go Go Gadget Mini Join Date: Apr 2007 Location: Newcastle Upon Tyne Local Time: 08:12 PM
Offline | It could be a number of things. I had a coolant loss not so long ago (3weeks) and it was down to a hole in something near the gaskett where the coolant goes in and the coolant was being burnt off in the engine. Take it to the stealer dealer and they will run a pressure test on it and find out where its coming from. If your under warrenty still there shouldnt be any charge. |
| What mod next? Join Date: Jan 2007 Location: Ludlow,Shropshire Local Time: 08:12 PM
Offline | Have a good look at the header tank its self, this can sometimes have a split on the centre joint. This may explain that the leak stops when it reaches a certain level and leak appears when running as when the coolant gets hot the tank will expand and open split more. Good luck as you need to get this sorted asap now the cold weather is on its way. |
| | #6 (permalink) |
| MINI2 Master Join Date: May 2003 Location: Brisbane, Melbourne Local Time: 06:12 AM
Offline | Ive had it happen to me 2 times on my 05 cooper, and i think a third time but I sold the car before I got a chance to check it out. It was the thermostat on both occasions. The car is out of warranty, but being a recurring problem they fix it for free. |
| | #7 (permalink) |
| MINI2 Newbie Join Date: Dec 2007 Local Time: 11:12 AM
Offline | I have the same problem, with my 2005 s with 59000 miles. I'll be taking it in for a pressure test. Mine only leaks after a long drive, then it sits for a couple of days and leaves a small 1 or 2 oz. puddle on the floor. But it does not do it all the time. About once a month! |
| Coolant Leak | Mess | Faults & Fixes | 15 | Aug 7th, 2008 12:24 PM |
| coolant leak | bluesmini | Faults & Fixes | 29 | Sep 10th, 2004 08:11 PM |
| MINI USA unaware of coolant leak problems... | Tom F. | Faults & Fixes | 13 | Sep 8th, 2004 03:15 AM |
| `02 mini cooper s coolant leak | BIGGUY05641 | Faults & Fixes | 4 | Dec 9th, 2003 12:19 PM |
| Coolant leak | minifreak | Faults & Fixes | 6 | Aug 28th, 2002 09:04 PM |
