Mighty Stripes
Old Nov 28th, 2007, 05:09 PM   #1
MIL7215
Local Time: 11:30 PM
Drivers Headlight not Self Levelling
Hi,
I have a 2001 Cooper with standard lights fitted. However with the dark nights i have noticed that the drivers diped light doesn't 'self level' as the passenger side does. When I move the rotary dial on the dash to the higher position only the passenger side rises. The drivers side will rise at best once in 30 attempts!!!
The stealership say that the levelling motor is part of the whole light assembly and I should replace the light at a cost of around £150 + fitting + vat.
I have taken the light out and cleaned the connections but this has made no difference. Would this be correct advice from the stealership or does something else control the levelling system that may be at fault?? Don't want to replace headlight if it may be something else
England   Reply With Quote
Old Nov 28th, 2007, 05:47 PM   #2 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
Lights are available on eBay for much less than £150!
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 28th, 2007, 07:33 PM   #3 (permalink)
MIL7215
Thanks for that.
I have had a look on ebay, but I am reluctant to change light if there be some other fault.
I'll keep looking for a solution.
Old Nov 28th, 2007, 08:47 PM   #4 (permalink)
Harpo
Havin' fun...
Harpo's Avatar
Hi MIL and welcome to Mini2.
Your dealer has got it right I'm afraid, and you will need to replace the whole unit as the motor is integral.
I had both mine go at the same time - 6 months out of warranty! Since they both went at the same time, my dealer moaned at BMW and successfully obtained a matching pair under warranty, so I just ended up aying for fitting.
I was given excellent service, a smart move by the dealer as I bought a new car from them a few months later.
United Kingdom Male View Harpo's Nightfire Red & White 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Self Levelling Xenon Lights iain34 Exterior 14 Dec 14th, 2005 09:26 PM
WANTED: Xenon Headlight (drivers side) Bosh For Sale 0 Sep 16th, 2005 06:51 AM
Xenon Headlight Auto-Levelling malfunction john_cook Faults & Fixes 3 Feb 10th, 2005 07:45 AM
Self-levelling headlights - only Xenons? miniwilly General Discussion 13 Aug 7th, 2004 08:57 PM
xenon levelling - up/down/flat you never know? mikeythemini Faults & Fixes 0 Nov 4th, 2002 05:37 PM
