Old Dec 4th, 2007, 12:27 PM   #1
tintopracer
Local Time: 01:19 AM
brake dust
What's the best stuff to get lttle black smuts of brake dust off my rims? I 've used alloy wheel cleaner which shifts the worst "dirt" off but still have some little black smuts on the rims.
Any recommendations other than a toothbrush and elbow grease?
Old Dec 4th, 2007, 12:47 PM   #2 (permalink)
minicabrio
Clubman Convert
minicabrio's Avatar
Try a tar removal polish on a cloth
Once you've got them looking top notch, a coat of normal car wax will help prevent future build up
Old Dec 4th, 2007, 07:37 PM   #3 (permalink)
Nebdingo
ProNet:3 Gaming Community
Nebdingo's Avatar
Send a message via ICQ to Nebdingo Send a message via MSN to Nebdingo Send a message via Yahoo to Nebdingo
A good quality tar remover should do the trick.
and as minicabrio says, car wax... or a wheel sealant to stop it.
I use turtlewax wheel gaurd, it wont stop the brake dust but it makes the wheels "glossy" and are far easier to clean.
England Male View Nebdingo's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 4th, 2007, 07:48 PM   #4 (permalink)
Tigger, Eeyore & Roo
I'm Back!
Tigger, Eeyore & Roo's Avatar
I've used Turtle Wax wheel guard for the last 2 or 3 years and 30,000 ish miles and it's brilliant. The brake dust simply washes off every time and I've not had to use a drop of wheel cleaner in all that time.
Tigger.
Unintimated and I'm back!!
For sunshine, fun and Cornish Pasties: New MINI Kernow Cornish Oggy Run 2009!
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 26th, 2007, 06:01 AM   #5 (permalink)
Gnawme
MINI Moo
Local Time: 05:19 PM
I used detailing clay (retired from paint cleaning duties -- using it on your paint after removing schmutz from your wheels is a bad idea) on wheel grit to great effect. Waxing the wheels afterwards helps prevent a recurrence.
Old Jan 5th, 2008, 04:50 PM   #6 (permalink)
mini33
Perfectionist Cooper S
mini33's Avatar
I recomend Supagard, i am a complete perfectionist & you name it i have tried it & always go back to supagard.
I have tried it on cars that have been treated & not treated & its works a treat.
My mums the complete oposite & never cleans hers unless i clean it for her & i always works a treat.
The cleaner works like a foam & easlily washes off & then apply the alloy wheel protector & that prevents the brake dust sticking so much .
The cans last for ages dependant on how often you clean them
You best bet is to get them of ebay
Hope thats helps
Old Jan 5th, 2008, 10:03 PM   #7 (permalink)
2005WORKS
2005WORKS's Avatar
United-Kingdom Clean wheels
Hope thats helps
Car Plan do a similar Nano-technology wheel protector (lasts upto 3 mths), which I have used to good effect for a while now from Halfords. Also used Autoglym version which is also good, but has to be applied more often.
Obviously your wheels have to be mint before you can apply these products, as they seal the wheels and once its on you don't want to strip the wheels back by using mild acid wheel cleaners, not that you will need to! As others have said you will only need to use soap and water thereafter.
Old Jan 7th, 2008, 12:33 PM   #8 (permalink)
MKIR53
MKIR53's Avatar
Local Time: 08:19 PM
as far as getting the brake dust off in the first place, i have used Meguiars. works well, depending on how much and how long its been there.
but the tool i swear by is the Powerball. i have the Powerball mini and its great. it is made of several strips of fynthetic foam in the shape of a ball (obviously) and it attatches to the chuck of a power drill. it comes with an extension so you can get all of the way to the back of the rim.
i have the web-spoke 17s and it works well on them, partly because the surfaces are large and there ore not a lot of little fussy areas.
the other option, which is way more fun is to stop using your brakes
Old Jan 7th, 2008, 01:38 PM   #9 (permalink)
MKIR53
MKIR53's Avatar
DIY tMother's Powerball MINI (as in small, not the car :) )
i tried to post some links for you but apparently i am too new to this site to have that kind of extraordinary privelage. Wierd, but whatever.
Anyway, the tool is sold by Mother'sŪ and its called the Powerball mini.
Shouldn't be too hard to find.
Old Jan 8th, 2008, 12:30 PM   #10 (permalink)
tintopracer
thanks for all the tips. All I need now is some warm weather and to have the time to give her a good clean
Old Jan 14th, 2008, 02:31 PM   #11 (permalink)
googly
Local Time: 12:19 AM
I use detailing clay to remove the stubborn marks and Bilberry Wheel Cleaner for regular cleaning which is acid free and works really well.
Brake Dust dougwc Wheels, Tyres & Brakes 8 Oct 30th, 2006 10:12 PM
Brake Dust Ell P Wheels, Tyres & Brakes 15 Apr 13th, 2006 11:49 AM
Brake Dust!?!?!?!? AckerMINI Maintenance & MINI Care 35 Jun 28th, 2004 09:49 PM
Brake dust? terpening Maintenance & MINI Care 15 Mar 18th, 2004 04:06 AM
Brake Dust Sausagefingers Wheels, Tyres & Brakes 20 Nov 15th, 2002 11:11 AM
