Visit Derek Woodman MINI
Tags: , ,
Old Jan 14th, 2008, 05:37 PM   #1
PmP
GP 0380
PmP's Avatar
Local Time: 04:53 AM
Service/Inspection Intervals
Right, my mini manuals arent very clear on this. Or im not taking the time to read it.
But what are the service/inspection approx mileage intervals recommended by Mini.
Trying to work out if my cars due an inspection 1 or 2.
50700 miles currently on car.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 14th, 2008, 05:43 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 08:53 PM
Approximate mileage for 1st Gen MINI servicing ...
  1. 10K - Oil Service
  2. 25K - Inspection 1 Service
  3. 40K - Oil Service
  4. 55K - Inspection 2 Service
  5. 70K - Oil Service
Repeat 2 through 5 at 15K intervals
From Build Date ...
Every 2 years - Brake Fluid Change
Every 4 years - Coolant Flush
Old Jan 14th, 2008, 05:52 PM   #3 (permalink)
PmP
GP 0380
PmP's Avatar
When do spark plugs, v belt get changed?
So they should carry out an engine flush as part of my Inspection 1 then at 52,000 miles?
Or should I mention it? As cars four in February. Its going in tomorrow for the inspection just wasnt sure which one.
Whens the oil get changed then?
Old Jan 14th, 2008, 06:21 PM   #4 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Changing the V-belt is part of Inspection 2 Service.
Spark Plugs and Oxygen Sensor are changed at 100K intervals.
Inspection 1 & 2 Services include an oil change.
On your MINI's 4th "birthday" it would be due its 1st coolant flush and 2nd brake fluid change. When was your last brake fluid change? Unless you want to take the car back in next month, it probably makes sense to have all these things done with your Inspection Service.
Old Jan 14th, 2008, 07:06 PM   #5 (permalink)
PmP
GP 0380
PmP's Avatar
Are you sure about that? So my oil should get changed at every inspection?
Will take it in tomorrow and ask exactly what they are planning to do. Cause I'm pretty sure they arent planning to change my oil tomorrow.
Edit
Are you talking in miles or kilometres Miniac?
Old Jan 14th, 2008, 07:32 PM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Yes, an oil change is included with each Inspection Service.
The intervals I've given are in miles.
Old Jan 14th, 2008, 07:58 PM   #7 (permalink)
PmP
GP 0380
PmP's Avatar
Wondering is there a difference in US and UK servicing.
Anyone in UK clarify this?
Old Jan 14th, 2008, 08:05 PM   #8 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Didn't you get a Service Book which details the services?
Old Jan 15th, 2008, 10:45 AM   #9 (permalink)
minibutmighty
minibutmighty's Avatar
Local Time: 03:53 AM
Well I did, but even it isnt clear. Took car in today and the service advisor tells me the car is only due an oil change not an inspection 2.
So when they argued it was due an inspection 2 on the fone, they were wrong.
It seems our service intervals go
Oil service
Inspection 1
Oil Service
Inspection 2
Oilservice
Inspection 1
Oil service
Inspection 2
Old Jan 15th, 2008, 11:10 AM   #10 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Oil service
Inspection 1
Oil Service
Inspection 2
Oilservice
Inspection 1
Oil service
Inspection 2
Yes, that's correct... the intervals are:
Oil service - circa 10k miles
Inspection 1 - circa 25k miles
Oil Service - circa 35k miles
Inspection 2 - circa 50k miles
Oil service - circa 60k miles
Inspection 1 - circa 75k miles
Oil Service - circa 85k miles
Inspection 2 - circa 100k miles
Brake fluid change is every two years.
Old Jan 15th, 2008, 11:21 AM   #11 (permalink)
KPKalle
Knight of the Round Table
KPKalle's Avatar
From Build Date ...
As MINIAC says, and just to stress the point, these intervals are for the 1st gen MINI not the R56. The first service at all for the R56 is at about the 20K mile mark
Global Moderator
England Male View KPKalle's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Jan 15th, 2008, 12:33 PM   #12 (permalink)
oldnell
One additional item you might want to consider is that the air filter doesn't get changed other than at a service 2. If you're having a service 1 done, you might want to think about getting an extra air filter change too.
Oli
View oldnell's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 15th, 2008, 01:03 PM   #13 (permalink)
PmP
GP 0380
PmP's Avatar
The thing I dont understand is ive 50k miles on the car and its only due the 2nd oil service, which should have occured around 35k miles?
This must be down to the on-board computer altering intervals? depending on the cars useage. Seems a bit odd tho to adjust the intervals to a point were its about 15k miles out or does that sound reasonable?
Old Jan 15th, 2008, 01:11 PM   #14 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Its all down to how the car is driven... if you managed to cover say 15k before it needed its first oil service, and then eaked anotth 5k out of every service you'll end up 15k in front
My car on the other hand needed an oil service at 8k
Old Jan 15th, 2008, 01:27 PM   #15 (permalink)
PmP
GP 0380
PmP's Avatar
The car did do motorway miles, but it hasnt for a year n a half now, so its odd tha it should be extended so much, not like i drive like a granny. Just considering the likes of the poly belt, plugs, oil filter etc should be changed after 50,000 miles, wont get dont til to 70,000.
Old Jan 15th, 2008, 04:38 PM   #16 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Corrected my initial post to include Oil Services between Inspection Services
When the Service Interval Counter was reset on my MCS following the initial Oil Service and Inspection 1 Service it read 15,500. Based on this I'm assuming there is a 15K interval between each of the services.
The attached indicates that an oil change is included as part of an Inspection 1 or 2 Service.
File Type: pdf 2002 MINI Service Maintenance Checklist.pdf (1.33 MB, 86 views)
Old Jan 16th, 2008, 07:55 AM   #17 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Yes, an oil change occurs at every service... Oil services are just an oil change and a new oil filter, the Inspection services includes more service items.
The schedule I posted above was correct on my '04 Cooper Cabrio, sold with 57k on the clock
Old Jan 17th, 2008, 10:14 PM   #18 (permalink)
PmP
GP 0380
PmP's Avatar
Issue with the TLC system, car thought it didnt need an oil change for 23,000 miles.
The new engine mount has really really transformed the handling back to the way it should be.
Old Jun 9th, 2008, 10:25 AM   #19 (permalink)
MOCKSY
MOCKSY's Avatar
Send a message via AIM to MOCKSY Send a message via MSN to MOCKSY
I AM ABLE TO SERVIE MY CAR MYSELF.
i KNOW HOW TO RESET THE OIL SERVICE TRIP. WILL THIS ALSO RESET THE BRAKE FLUID TRIP ITS STILL GOT 200+ DAYS TO RUN.
HOW AM I ABLE TO READ AND RESET ANY FAULT CODES?
HAS ANYONE TIRED ANY OF THE CD'S ON EBAY FOR PLUGGING IN YOUR LAPTOP, SURE I'VE SEEN SOME AT TIMES OR HAS ANYONE HAD ANYLUCK WITH GETTING BMW JUST TO CHECK THE FAULT CODES.
THANKS DAVE
United Kingdom Male View MOCKSY's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 9th, 2008, 10:40 AM   #20 (permalink)
Snowie
Snowie's Avatar
Why are you shouting?? - using capital letters.
Brake fluid change and service times are indepent of each other.
Brake fluid is a count down of days from build or last change = 2 years
Service is miles based with a computerised driving factor built in
If you want to read fault codes yourself then I woyuld suggest that you buy a scangauge - do a search on here and you will find a few threads on scangauge.
If you want to reset brake fluid / service indicator then again do a search and you will find a few threads on how to do it on first gen MINI
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
R56 Service Intervals KenL 2nd Gen MINI Cooper 27 Mar 6th, 2007 12:12 PM
Service Intervals ! Echo_Steve MINI Cooper S 3 Mar 19th, 2006 05:36 PM
Service Intervals, Inspection I/II PigLick Maintenance & MINI Care 2 May 12th, 2003 10:19 AM
Service Intervals PeterG MINI Cooper S 4 Jan 13th, 2003 01:46 PM
What is service intervals on an '02 MCS and '03 MCS? 2fast4u2pass MINI Cooper S 1 Oct 31st, 2002 03:29 PM
