| Tags: supercharger |
| MINI2 Newbie | Supercharger - Probelm ? HI My JCW works mini (2003) had a strange 'rattlely sound' on tickover. Appeared to come from the top of the engine around the supercharger area. Mt Friend (a mechanic) suggested he thought it could be bearing noise - suspected supercharger bearing . We have now romoved the suspect part. When we start to rotate the blades their is a destinct 'click' . If rotation continues no more noise. Is this normal ?? If you wobble the pulley from side to side the 'click' dontinues. We were wondering if the gearing may be a little worn. Car has 50k ish miles. Otherwise seems to rotate OK , Does any one know how to diagnose a supercharger problem and how easy ought they spin? Cheers |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 11:25 PM
Offline | You will have to remove the water pump from the charger- It sounds like the gears are knackered-check the teeth -they may well be gone ,not uncommon -was any oil in the charger? or signs of leak? No one services the charger oil and they can fail !! |
| Interior Indicator light Probelm | Woza | Faults & Fixes | 4 | Oct 19th, 2006 09:31 PM |
| DIY Supercharger | paulbin | Engine & Drivetrain Tuning | 5 | May 4th, 2006 10:45 PM |
| Mini Clutch Probelm | Genevieve Goh | Faults & Fixes | 2 | Jun 3rd, 2005 01:07 PM |
| MCS Supercharger vs Works Supercharger | LMB | John Cooper Works & GP | 60 | Jul 15th, 2003 07:41 PM |
