| Tags: door, stay, stop, torx |
| MINI2 Master | Reverse Torx screw on door stay? I searched the forums before posting for help. What kind of reverse torx screw is this? My first generation MINI Cooper S has a passenger door that is clicking when opening. I've traced this to the spring-loaded door stay or stop that holds the door open at various positions. The attachment to the door frame is loose, and the spring lash between stops is causing it to move a little. It is attached to the door with a screw or bolt, that looks like a large torx bit. So to tighten it, I would need something like a socket that you could put a large Torx bit into. Anyone know what this tool is called or where to get one? Bonus points if the retailer is located in Canada. Thanks for any help, /\/oah. Chilli Red/White Cooper S, Sport Pack & Sunroof. Delivered June 12th, 2002!Now with MCS Winter Tire Package. |
| MINI2 Regular Join Date: Jul 2007 Local Time: 05:06 AM
Offline | Have a look here (in the bottom RH corner) RealOEM.COM * BMW R53 Cooper S FRONT DOOR-HINGE/DOOR BRAKE Is it component 8 the M8 torx screw? You should be able to buy a std socket for that? |
| Mustn't Grumble... Join Date: Jun 2005 Local Time: 12:06 AM
Offline | It's an external Torx or E Torx. You can buy a "cheap" set at Princess Auto on Dixie Road. www.princessauto.com |
| MINI2 Master | Thanks everyone! Wow, a one hour answer. BMW wouldn't even get back to me that fast. That's it exactly, component #8. A 22mm Male Torx screw. I've only ever seen Female Torx screws, I have a number of Male Torx Bits. A Female Torx socket is _exactly_ what I need, thanks. Also called external Torx, I suppose. Bonus points to XRV848 for finding me a source in the GTA. A good excuse to get out to Princess Auto as well. ![]() I knew MINI2 members would have the answers, thanks to both of you! /\/oah. Chilli Red/White Cooper S, Sport Pack & Sunroof. Delivered June 12th, 2002!Now with MCS Winter Tire Package. |
| Door won't stay shut | Hansii | Faults & Fixes | 3 | Dec 13th, 2007 12:17 AM |
| Drivers Door Wont stay open! | Matthew Boocock | Faults & Fixes | 2 | May 29th, 2007 09:02 AM |
| chrome door inserts - screw covers | ##~James~## | Interior & Ice | 2 | May 15th, 2007 09:00 AM |
| Destroyed Nuts for the Door Panel torx screw | Rupta | Faults & Fixes | 1 | Nov 13th, 2004 08:00 PM |
| How do I remove a sheared torx screw? | stellablade | Faults & Fixes | 7 | Aug 8th, 2003 12:30 PM |
