Old Mar 28th, 2008, 12:47 PM   #1
hoojkel
Local Time: 01:42 PM
Oil Change Kit
Hi,
Is there a complete kit you can buy from the dealers for an oil change, including filter,new drain plug etc or are they all separate parts you have to get?
Northern Ireland Male   Reply With Quote
Old Mar 28th, 2008, 12:53 PM   #2 (permalink)
Rakey
Four Candles?
Rakey's Avatar
Seperate parts normally, but speak to Chris at Woodmans, I am sure he did a service kit for people
Old Mar 28th, 2008, 12:54 PM   #3 (permalink)
hoojkel
Cheers Rakey, I heard of a service kit somewhere but wasn't sure if it actually existed!!
Old Mar 28th, 2008, 02:22 PM   #4 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 08:42 AM
Talk to Minimania UK (Adam). he should be able to set you up with all the bits you need.
Global Moderator
Old Mar 28th, 2008, 02:38 PM   #5 (permalink)
hoojkel
I did look at minimania as they had the plug but only on the U.S. site, not on UK site, even checked the part number for it.
Old Mar 28th, 2008, 04:38 PM   #6 (permalink)
MINIMANIAUK
MINI2 Sponsor
Service kit -no problem ,I am adding a huge amount of items and this will take time , including service kits for various tasks , with any special tools required included ,such as filter socket .
Year changes present a problem as do model differences so there are quite a few part numbers for the same items.
It will take time ,and once finished for any defect on the MINI the repair part will be available,also as more people use us prices can be dropped ,
I am also looking further ahead ,for rebuilt or repaired control units,drive shafts,and replacement panels etc and even wire loom repair kits ,so the whole loom need not be replaced if only a connector is damaged .
Every weak point on the car I am looking at providing an improved part for, to keep the car trouble free, but it is a lengthy process
(,for example stainless steel exhaust mounting brackets,improved heater matrix ) these type of jobs you only want to do once!!!
OEM parts have for a long time been considered the replacement parts to use ,but when they are failing with alarming regularity, a bit more selectivity is required
A
Old Mar 29th, 2008, 02:46 PM   #7 (permalink)
hoojkel
Cheers Adam, a complete oil service kit would be very handy!!
Oil Pressure Light After Oil Change tpwmini Engine & Drivetrain Tuning 6 Apr 20th, 2005 02:50 PM
Oil Pressure Light after Oil Change tpwmini Faults & Fixes 0 Apr 16th, 2005 03:46 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
oil cooler-Does it drain when when having oil change? yorobby MINI Cooper S 4 Sep 29th, 2004 12:00 AM
First oil change> Do I have to drain oil cooler ? yorobby Maintenance & MINI Care 3 Sep 26th, 2002 07:44 PM
