| Tags: help |
| MINI2 Newbie Join Date: Apr 2008 Local Time: 04:51 AM
Offline | how to change the door cushions?? the cushions on my door are looking a bit worn and i would like to replace the material but i cannot work out how to get them off the door??????????Pip ![]() |
| MINI2 Master Join Date: Dec 2002 Location: Malmesbury, Wilts Local Time: 04:51 AM
Offline | Assuming you have a first generation as I can't imagine an R56 being worn yet then you have to buy the whole door panel .![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
![]() MINI2 Master Join Date: Jul 2006 Location: Essex Local Time: 04:51 AM
Offline | if you mean first generation you can actually slide off the door cushions, its a bit fiddly but you have to slide a flat-head screwdriver under it from the side nearest the front of the car and it will push down a tab and then you can slide it off....be careful not to scratch anything while doing this crammy ![]() ![]() ![]() ![]() ![]() |
| MINI & other ½ both whine Join Date: Nov 2007 Location: Messing with a MINI Local Time: 04:51 AM
Offline | That's the face-lift model "Crammy", I think the pre face-lift ones are actual plastic welded on and need drilling off etc... etc... .Maybe a little more info next time "lil red mini" .![]() ![]() ![]() Destined to live life £5 behind. Disclaimer ![]() |
| | #6 (permalink) |
Offline | The screws hold the whole door trim to the door, the armrest doesn't come off separately. Nice spot for the Moss replacements but no sign of them in the Moss Europe catalogue .![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| | #10 (permalink) |
Offline | The 1st Gen face-lift do come off (07/2004 on-wards) by a implement to push down the catch etc... and then slide it (cushion) off. I am going to double check tomorrow as I'm sure these (cushions) don't just screw off on the 1st Gen pre face-lift before 07/2004, hence my above comment, although I've seen them removed (not by me) so I'm not 100% sure and I could be wrong .![]() ![]() ![]() Destined to live life £5 behind. Disclaimer ![]() |
| | #11 (permalink) |
Offline | You're totally correct "MINIAC" I stand corrected (I did say, think ) the arm rest / cushion is fastened on with three screws (1st Gen pre face- lift) you can see where the three fixing holes, where they are situated in the attachment by "MINIAC", there is a but they are screwed in from behind at an awkward angle, there is little access, you'll need a small star bit (I tried a TX 10 and that was too big, so it was smaller than that unless the bit I using was a wrongly sized ), and one of the miniature bit ratchets, the smaller hands the better, it's very fiddly.![]() ![]() ![]() Destined to live life £5 behind. Disclaimer ![]() |
| can you change the colour of the lights in the door handles inside my mini?? | jcw 60 | Interior & Ice | 3 | Jun 2nd, 2007 08:51 PM |
| Removing Alloy Patina elipses and door pockets from door cards | Tigger, Eeyore & Roo | Interior & Ice | 6 | May 22nd, 2007 10:20 PM |
| Does the wheel offset change if you change the width of your wheels? | Root Ginger | Wheels, Tyres & Brakes | 6 | Feb 23rd, 2005 10:22 AM |
| After-market cushions etc. for Mini back sufferers | Kraigster414 | Interior & Ice | 1 | Mar 3rd, 2004 09:43 AM |
