R56 Service / Brake lights etc Reset Proceedure - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 11th, 2008, 03:23 PM
ONED's Avatar
SUCKIN DIESEL!!!!
Local Time: 01:27 AM
United Nations Male View ONED's Nightfire Red & Black 2nd Gen MINI Cooper Diesel Profile
OK Folks the info you have all been waiting for - sorry it took so long to compile - but have managed to get round all those R56 service light resets. The main one people are asking for is the Brake indicator reset after changing pads and fitting a new sensor, but the procedure is the same for all service indicator resets.
Please do not reset any of your service lights if you have TLC cover for this work.
I take no responsibility for how this info may be used!
Anyway......
To enter the service Menu:
Insert Key
Do not press clutch / brake
Press Start button
Wait until the Car / revelant Service symbol disappears on the Rev counter display
Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system Will run a dash light check
Continue to hold
Display will then show VIN / Menu, - continue to hold through this until the time Reappears on the display.
Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second or 2 the display will show the Front Brake Symbol You Are Now in the Service Menu
Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Rear Brakes
To Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete.
Turn Off and On the Ignition again - Warning should now have gone!
Good Luck !
Mods can you please add a copy of this Info to the FAQ & DIY Section, and can you also Sticky this?
Old Apr 16th, 2008, 04:44 PM
MINIAC's Avatar
Canned
Local Time: 05:27 PM
This has been reformatted and included in the FAQ:
DIY: How to reset service indicators
Old Jun 21st, 2010, 10:01 AM
adam_Randell's Avatar
Send a message via MSN to adam_Randell
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
i cant get it to work
Old Sep 12th, 2011, 09:53 PM
Local Time: 07:27 PM
BIG NOTE!!! Close your door! I spent over 30 minutes sitting in 90 degree heat and didn't think t close the door. Goes pretty quick after that!
Tags: , , , , ,
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Reset brake fluid service indicator? ocoro02 Wheels, Tyres & Brakes 1 Aug 22nd, 2007 03:13 PM
Service Reset Indicator GTT 280 First Generation MINI Tuning 1 Oct 31st, 2006 07:19 PM
any one know how to reset the service counters bemini First Generation Interior & Ice 2 Aug 30th, 2006 06:28 AM
Is there a service reset tool that resets airbag lights too. Root Ginger First Generation Faults & Fixes 8 Jun 29th, 2006 09:03 AM
How to reset service interval after service welshminiman Maintenance & MINI Care 1 Nov 6th, 2003 10:42 PM
