Mighty Stripes
Old May 7th, 2008, 01:14 PM   #1
Dr. J
Local Time: 03:14 PM
Gas Gas Gas
I'm sure this has been debated but what *type* of gas is everyone using? 87, 88, 89, 91, 93,... 103? (yes I have seen stations that sell 103!)
I was careful to elaborate on this with my dealer as he said the "manual calls for 89" (before I bought the car). Online I've seen everything from 87 to 91. fueleconomy.gov says "Premium" but that means different things to different people. (I guess "premium" is anything more than 87)
With the actual manual in my hands it says that 91 is "highly recommended" but that the "minimum is 87". I'm still on my first fill up from the dealer and I'm not sure what he put in it.
The incentive is clear - it's roughly a 10 cent bump per grade - and if 91 is not absolutely required, or won't affect the MPG that much then there's no sense in putting in 91. Around here, there's roughly a 10 - 15 cent difference between 89 and 87, then 10 cents more to 91 and perhaps a few pennies to 93 (if the station sells it... usually it's either 91 or 93 but not both).
If regular (87) costs $3.75, that puts 91 at around $4, 7% more. Thus, it makes sense that if you can get a 7+% increase in MPG, filling with 91 makes sense economically.
Thoughts?
Old May 7th, 2008, 02:51 PM   #2 (permalink)
dlpruk
dlpruk's Avatar
Local Time: 08:14 PM
Don't forget that the knock sensor will retard the ignition - and thus reduce the performance and fuel consumption - if you use lower-grade fuel so it's not just the cost premium to consider.
David
United Kingdom Male View dlpruk's British Racing Green & Body Color 2nd Gen MINI Cooper Diesel Clubman Profile   Reply With Quote
Old May 7th, 2008, 03:06 PM   #3 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 12:14 PM
The engine will perform best using 91-93.
Old May 7th, 2008, 04:54 PM   #4 (permalink)
Dr. J
yeah I know that while the car *can* run on say, 87, there is a performance hit, but the question is - how much of a difference does it make? If the % cost increase is less than the % MPG increase then it' "worth it" economically. There are other factors like engine health/longevity which are harder to quantify.
Old May 7th, 2008, 05:02 PM   #5 (permalink)
Rakey
all good things.......
Rakey's Avatar
And even better if petrol is used, gas is for cookers and bbq's
Food rule fanatic
Old May 7th, 2008, 05:29 PM   #6 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
Send a message via AIM to AprilWhine Send a message via MSN to AprilWhine Send a message via Skype™ to AprilWhine
Some states even have gas with an octane rating of 94 available, does it do any good to use higher rated gas? I bought some in NJ for my GP but it did not have any noticeable improvements.
Global Moderator
United States Visit my Blog at the Motorcade Female   Reply With Quote
Old May 7th, 2008, 05:44 PM   #7 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Assuming 10 cents difference between grades of gasoline you're saving yourself only $1.30 (89 octane) or $2.60 (87 octane) per 13 gallon fill-up.
Drink one or two less beers between fill-ups and you and your engine will be better off
Old May 8th, 2008, 12:49 AM   #8 (permalink)
Dr. J
The only stations we have here are Mobil/Exxon, Citgo, Gulf, Sunoco and Hess - no Shell, Chevron, BP - will it make a difference *which* kind of station I fill up at?
Old May 8th, 2008, 06:12 AM   #9 (permalink)
DaFlake
I Win!!!!!!
DaFlake's Avatar
Local Time: 09:14 PM
Online
Not really, just find a station that you trust and go there.
Global Dispute and Flow Control Manager
Germany Visit my Blog at the Motorcade Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 8th, 2008, 07:37 AM   #10 (permalink)
Fevs
heading north !!!!
Fevs's Avatar
Send a message via AIM to Fevs Send a message via MSN to Fevs
or Kurds And any other nation that feels the need to use it !!!!!
Global motivator
England Female   Reply With Quote
Old May 8th, 2008, 02:27 PM   #11 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
Gas is (relatively) cheap, petrol is expensive. That's why I run gas.
Global Moderator
Old May 8th, 2008, 05:35 PM   #12 (permalink)
DaFlake
I Win!!!!!!
DaFlake's Avatar
Online
I have gas...
Old May 9th, 2008, 04:45 AM   #13 (permalink)
CCroker
Local Time: 02:14 PM
According to the manual on my 03 S, it says 91 RON which would be 93 at most pumps as RON is not the stated measure at US filling stations. MINIs will run there best ( performance and fuel wise ) at the better grade. As posted above the differences in prices amount to $1.20 to $2.40 a tank. Fuel injection cleaners cost $5-$6 a can. Plugs cost on average $10 each ($40) and oil and filter costs $40. You will also realize a 1-3 mpg cut in mileage increasing by 1% over each month using the lower grade fuel. So, if you fill up 3 times a week, you will realize an equalization in costs. But, if you fill up just once a week, the increased maintenance will overcome the difference of the cheaper fuel to the more costly correct fuel. If you do your own manintenance you will save again, but if you rely on a dealer or a service center, you've lost $ again. Do what the manual says, but do the services at half the intervals. 7.5K instead of 15K and replace plugs every 2 years not 100K. Plugs are only guarenteed by the manufactures for 2 years. Clean oil lubes better for mpg and use a good synthetic. Don't forget the transmission, manual says for life ( it does have a drain and fill plug). And tires, the most forgotten thing on the ground. Just because the monitor isn't lit doesn't mean you shouldn't check them ( fuel really gets wasted there). Do your maintenance a little more often and you will get more from the MINI and won't have anything to complain about. The MINI is rated #7 in the top 10 Green cars in the US. I can get 28 in town and 38 on highway and still punch it now and then.
Charlie Croker
BRG 03 Cooper S
SCCA Solo, PDX, Time Trials, RoadRally
Help? Gas Cap Conversion Kit...is it the new or old style gas cap? NeedMiniInfo Exterior 0 Aug 14th, 2007 10:16 AM
WTT - MCS Chrome Gas Cap for BLACK MC Gas Cap FastLaneTuning For Sale 1 Apr 12th, 2005 10:30 PM
gas station-->gas? janie_cakie MINI Cooper 1 Mar 5th, 2004 02:16 AM
What is the best gas in the US? azimmerm MINI Cooper S 21 Jan 28th, 2004 06:18 PM
The best gas? DThor Canada 9 Oct 24th, 2003 02:51 AM
