| Window side trim has come off! You know you have the front side and rear side windows on the passenger side. Between those you have a black vertical bit of plastic that is attached via double sided tape to the rear window. Well, mine's come off! Does anyone know where I can get hold of the black padded double sided tape they use to fix it to the window? I don't live near a MINI garage and don't want a wasted trip the garage. I also don't really want to buy a whole role of tape when it's only around 40cm I need |
| You can buy 3m double sided tape which is very strong and is used for sticking on mirror covers etc. You can pick it up from most decent newsagents/craft shops/halfords etc etc. Small roll is less than a tenner. |
| £10!!! I only want 40cm of the stuff! I may just have to leave it off until I venture past a MINI dealer and get them to give me some for FREE. Call me tight but this is something that shouldn't really fall off so I fail to see why I should have to pay for it. |
| Good luck to you in getting it free then from a mini dealer. Dunno how its just came loose but you can check ebay to get it cheaper. Why did you post a thread asking advice about where to get it and how much if you now believe you should get it free as "its something that shouldn't really fall off" ![]() |
| Tags: double sided tape, trim, window |
| Sticking window - now BROKEN TRIM!!!! | Volte | First Generation Faults & Fixes | 2 | Jun 2nd, 2007 10:58 PM |
| Plastic trim between doors and rear window | bradley_m | First Generation Faults & Fixes | 1 | Aug 6th, 2004 11:15 AM |
| Broken window and trim, need advice. | love you dead | First Generation Faults & Fixes | 4 | Jan 2nd, 2004 08:23 PM |
| Window Trim coming away | martin dymond | First Generation Faults & Fixes | 1 | Jun 24th, 2003 05:55 PM |
| No window trim!!! | Fullonloon | First Generation Faults & Fixes | 1 | Jul 9th, 2002 02:21 AM |
