How many quart of oil needed? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Sep 30th, 2002, 07:44 PM Thread Starter
Local Time: 09:52 AM
How many quarts (or lt.) of oil is needed for an oil change? I'm planning to change the oil and need to know many quarts to buy.
Thanks!
PS - This is not to start another thread about the benefits or waste of an early oil change. Please don't start that again for we have enough threads about that already.
This is how much I already know:
* Use Castrol Syntec 5W-30 or Mobil 1 5W-30.
* New oil filter PN 11-42-7-512-446
phong13 is offline
post #2 of 2 (permalink) Old Sep 30th, 2002, 11:44 PM Thread Starter
Re: Re: How many quart of oil needed?
Originally posted by obehave
It's at 4.7 or 4.8 Qts. US. You end up with a useless bit in a quart. During break in mine went down a bit between 600 miles (first oil change) and 1600 miles (second change). So keep the wee bit. You might need it. Just makes sure the cap on the quart is on tight.
Thanks obehave... I will keep that in mind.
phong13 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 11:23 AM
Mini Cooper S, slight oil leak, helped needed! Lainchers First Generation Faults & Fixes 6 Feb 23rd, 2013 11:24 PM
Dead Turbo needs replacing in 1.6 dooper Porn_Star19 General Discussion 0 Jan 24th, 2013 11:37 AM
Oil change needed? beaver MINI Countryman 1 Nov 2nd, 2012 07:44 AM
5w30 oil failure suspected ptjenki1961 Maintenance & MINI Care 9 Sep 1st, 2012 02:22 PM
