| Electric Window Morning Mini Addicts, My drivers door window often fails to work. There is a click when the window switch is depressed but window fails to work, doesnt even drop the little when you open the door. Then again sometimes it is fine. My dealer says new motor required at a cost of £285 fitted. I fail to see how a motor can come and go. Any ideas? Its an 03 Mini One btw. Thanks. |
| I've been having a similar problem with my driver-side window, except that mine isn't intermittent - it just plain doesn't work. ![]() My problem seems related to other electrical failures that all seem to be happening at the same time (can't purely be a coincidence, can it?): So keep an eye out for anything else unusual... I'm a bit lost on the whole issue, myself. ![]() Although, if yours is intermittent, you might also consider this thread: Good luck! All the best, Andrew. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
I had a final bill on Monday of about £310 to have the motor and regulator replaced for my drivers window. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| Come on people! This is America, right? Or is it? Never mind . . . The windows on the Mini are nororious for failing. And yes, they are expensive to replace. So fix them instead - like I did. You have to pull the window and regulator out of the door. Then take the motor apart and clean it up and put it all back together. Just be patient, gather your how-to data off the net, and have at it. It is not that hard. Believe me, if this Yank can do it anybody can. |
| Tags: electric, front, window |
| Electric Window Problem | el_corpo | First Generation Faults & Fixes | 52 | Aug 13th, 2009 05:28 AM |
| Odd Electric Window | super c00per | First Generation Faults & Fixes | 2 | Jul 29th, 2008 07:59 AM |
| Electric window not working again! | stacyb | First Generation Faults & Fixes | 1 | Apr 5th, 2008 11:43 AM |
| Electric Window Switches | +++MadMatt+++ | Maintenance & MINI Care | 6 | Feb 10th, 2008 05:51 PM |
| Electric Window doesn't work. | Crossbuster | First Generation Faults & Fixes | 10 | Dec 9th, 2007 09:44 AM |
