MOT - Did yours pass its first MOT without fault?? The MOT on my 06 plate Cooper (1st Gen) is due on the 1st March - its first MOT as it'll be three years old then. So, was wondering what chance I have of it passing without fault. The tyres / brakes are all good. So my questions to all you helpful people are: Did your MINI pass its first MOT without any problems? And if it didn't, what did it fail on? Any general pointers on what I should check over would be good too. Thanks folks! James |
| This is what I will do too. I've just advised my friend with a 55reg to do this recently too. Just take it to MINI while the warrenty is still in play and get it checked out pre MOT. Then any warrenty work will be done and covered. I think my friends "Health check" was free. ![]() |
| Yep - MOT will be done at the main dealer on the 16th. OK, so are there any known areas of concern for MINI MOTs that aren't warranty fixes? Thinking wheel bearings / seat belts etc. As far as I know everything is fine, just asking in case there is anything I can do to prepare it before the day. |
| Mine failed it's first at the MINI dealers. Exhaust mount and rear cliper rubber boot twisted causing the rear brakes to stick on. 2nd MOT I went independent and apart from the 1 tyre I knew about and had preordered it flew through. 3rd MOT, last week, at the same independent - sailed through no problem |
| mine failed for corrosion on rear brake discs, the dealer actually advised me to have the mot before the warranty was up so if it failed on any of the parts covered they could replace them free, the brakes wern't but it gave me an excuse to upgrade! They didnt mention a pre mot check or anything, sounds a bit like a con to get extra money to me |
| I had my Mot done last 0ct 2008 on my 55 mini 1D with 180,000 miles onthe clock . It failed on a small chip in the drivers zone on the screen..... cost me £50.00 then it pasted ! |
| Mot | hegie | General Discussion | 20 | Jun 20th, 2008 05:42 PM |
| where to go for MOT | tyrerc | Maintenance & MINI Care | 3 | Nov 25th, 2007 09:40 AM |
| Mot | MarkW19 | General Discussion | 19 | May 16th, 2006 05:42 PM |
| Non run flats, pass MOT? | Mini8 | Wheels, Tyres & Brakes | 9 | Dec 7th, 2005 10:22 PM |
| Mot | RVW | General Discussion | 1 | Nov 13th, 2003 07:13 AM |
