painting plastic trims - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 14th, 2009, 12:59 PM
alski's Avatar
dyno-mite, might not....
Local Time: 03:33 PM
England Male View alski's Classified Ads
is the bmw oem spray paint ok straight onto plastic trim? [arch] or should i use some kind of plastic primer 1st...
carefree
Old Mar 14th, 2009, 02:05 PM
chris oakman's Avatar
United Kingdom Male View chris oakman's Hyper Blue & White 1st Gen MINI Cooper Profile
you should palstic prime them and then if you want the smooth look you willl also need to filler prime them to smooth them out or they will look rough and imo poo
Old Mar 14th, 2009, 02:06 PM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
What he said
Old Mar 14th, 2009, 04:13 PM
minicabrio's Avatar
Soon to be deleted !!
Local Time: 02:33 PM
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Sand the surface smooth first, and clean with alcohol to remove any residues.
Use a primer, then sand again with ultra fine 2000 grit (wet preferably), clean again with alcohol, then colour coat (at least three coats), then top lacquer (at least two coats).
The key to any good bit of paintwork is the preperation
Old Mar 14th, 2009, 05:02 PM
crofty136's Avatar
United Kingdom Male View crofty136's Classified Ads
and if your doing it in a garage or shed or whatever i would spray water on the floor and walls etc to try keep the dust under control, The finish you get will never look as good as if it was professionaly sprayed
Old Mar 16th, 2009, 12:52 PM
alski's Avatar
halfrauds plastic primer and 800 grit with lots of water looking good so far...
but can you sand clear coat?
carefree
Old Mar 16th, 2009, 02:45 PM
minicabrio's Avatar
You can sand anything providing you use the correct grit paper
There are loads of guides to spray painting on the www... like this one
How to Do a Good Base Coat Clear Coat Paint Job - wikiHow
Old Mar 30th, 2009, 06:57 PM
United Kingdom View Max M4X WW's Classified Ads
How smooth do the arches become when painted? They are grained from factory!
Plastic trims stolen, need some replacement... ibimbo First Generation MINI One 18 Dec 21st, 2004 09:39 PM
BMW painting instructions (aerokit, ABS plastic). Refrigerator Johnny First Generation MINI Exterior 2 Sep 8th, 2002 05:31 PM
Help ! How do you remove the rear plastic trims/fenders batman First Generation MINI Exterior 0 Jul 10th, 2002 11:17 PM
painting plastic body pieces Kyle K. First Generation MINI Exterior 8 Jul 5th, 2002 05:14 PM
