| Engine Coolant Hi i just wondered how often i should have to top my engine coolant up? mine seem to need topping up every few weeks or so! inother cars ive had ive never filled the coolant up for months! just wondered if i had a leak? |
| Hi thankyou for your replies!!! should i be putting water in the coolant tank? im going to book it into the dealers for them to have a look. The car is still under warranty does anyone know if the thermostat does need replacing will it be covered under the warranty? Thankyou |
I only got my Mini less than 2 weeks ago and the coolant is way below the min level. Called the dealership and they said this shouldn't be the case and to bring it in on Monday!! ![]() My gf had the same issue with her Mini where there coolant was leaking into the radiator and needed a whole new radiator. |
| Well i had this problem too...they had my car in for over a month fixing her. 2006 cooper with less than 11k on the clock...had a total loss of coolant every 2 weeks. They ended up changing thermostat & head gasket etc...all under warranty Just yesterday i called them out again as i've only had her back 3 weeks and had total loss of coolant again ...they said it was head gasket settling in. Grrr |
| my 2005 cooper's in the garage now, sounds like the same problem. lost coolant, checked, informed the thermostat was leaking and that was fixed.However 2wks later, same thing, car returned, nothing visible found, so now theyve removed the head, again nothing visible found, so the heads now being sent off for pressure testing ![]() ive only had the car 3months(2nd hand), it doesnt give me much faith in the car at present ![]() infact feelin sick out of the 4 months ive had the car, its been in the garage 1 month. Hopefully i should know more by the end of the week................... ![]() Any update's from you other folks out there with this problem?? |
| Finally got my mini back today ![]() they changed the thermostat and housing again, put a new gasket, bolts an d housing set on. Hope this has sorted the problem , but only time will tell......... the mechanics still arent sure what the actual problem was/is??? ![]() I'll keep you folks posted....anyone else had any more news? |
| well, had the mini back for 2 days and still losing water after 80 miles ![]() back to garage, told this may be due to air settling etc, and that the coolant top up tank isnt actually an expansion tank, as the whole system is pressureised and that part isnt, fliud is drawn from this when needed, tank topped up , another 30 miles on still losing!!!!!!!!!!!!!!!!!!! ![]() problem now solved!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! mini going!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! had enough now ![]() how have you folks got on?? |
| My 03 S has been loosing coolant for many months. You can smell it when you get out of the car but see no sign of any leak. Left the car with stealer for two days to check and reported that no sign of leak but could smell coolant. SUggested I should change radiator, hoses, bottle, thermostat housing if I wanted a fix!!!! I walked out after paying £80 for that diagnosis !! ![]() I feel like putting in a bottle of Radweld in to see if it fixes the leak. Any used Radweld on a MINI before ???? |
| Engine Coolant? | benjiboy8000 | First Generation MINI Tuning | 5 | Feb 13th, 2009 12:02 PM |
| Problem with Engine Coolant | libby.brown | Second Generation Faults & Fixes | 7 | Apr 11th, 2008 07:28 AM |
| changing engine coolant! | bemini | First Generation MINI Tuning | 7 | Jul 19th, 2006 10:21 PM |
| Help!!! Screen Wash In Engine Coolant | Sparkybhoy | Maintenance & MINI Care | 5 | Dec 11th, 2005 08:55 AM |
| Engine coolant in my new Mini S | timmy | Maintenance & MINI Care | 5 | Oct 31st, 2002 01:41 AM |
