Slick 50 Oil Additive - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 16th, 2009, 04:25 PM
MrE
Local Time: 10:27 AM
Wales
Well every car I have ever purchased I always add slick 50, which is an oil additive, its got liquid ptfe in I think. Basically drain the oil out and you can still drive the car at 50mph and not cease the engine – so they claim. Well as a builder, I tend to abuse my vehicles really bad. The proof for me on the slick is when I had a rover 218 diesel, put slick in as new. 3 years later driving through lanes to Aberwrystwth from Cardiff via Brecon lanes, I developed a water problem and popped the head. My choice was go home, cost £700 in wages or go for it. I drove the next 100 miles as per normal, with all the oil in the water like a grey mousse :-) I thought if the engine ceases so what, buy a new car.
Well it got me there and even back home, had head repaired for £100 all sorted. So I got some faith in that additive. When you put it in, it takes a third out of your temp gauge. So my question is this. Is it fine to put in the Diesel mini. The dealership reckon that it will do more harm than good, yet they’ve never heard of it. Plus it could invalidate my warranty.
My gut feeling is yes it will do good, as it coats moving parts, but then who knows it could coat non moving ie inlets, filter etc which is not so good. I’m probably going to leave it out until the warranty runs out. Has anyone put it in their beauty, what to the enthusiasts or mechanics think? Many thanks :-) MrE
Old May 16th, 2009, 11:07 PM
Anthony_h's Avatar
United Kingdom Male View Anthony_h's Classified Ads
cant offer any advice using it on the mini but ive always used active8.Lee a guy i used to talk to who is a vauxhall nut and had his own garage tunning and so on but he used to track his cav gsi v6 got me into using it, but it looked as tho it worked and did what said on the tin as he did a r&r day testing and seen small improvements on the dyno using it, how accurate it was i dont know but the paper was there with printed on. But i do plan on using it as managed to shut the noisey tappets up on my mk3 astra gsi and my mr2 was a bit noisey to worked on that to.
Old May 16th, 2009, 11:31 PM
DaFlake's Avatar
MMC Member
Local Time: 04:27 AM
Slick 50 is snake oil. As long as you keep your oil changes on schedule, you don't need an additive. Save your money and buy some nice mods.
Old May 17th, 2009, 09:08 PM
Local Time: 09:27 AM
United Kingdom Male View Porn_Star's Classified Ads
use Slick 50® Diesel Engine Treatment which is specially formulated for diesel engines (got that off the Slick 50 web site). But that being said I would never use it myself! It is pretty thick what will it do when it passes through the injectors? I would imagine most of it gets "sucked" in the oil filter anyhow.
But hey you never know... I did not even know they still made this stuff!
Old May 18th, 2009, 08:21 AM
still learning
Scotland Male
I used these type of products years ago......Molyslip/Slick 50, etc
great in old engines with high mileage.
nowadays I would agree with your dealer that they could do more damage than good in a modern engine such as the Mini.
the engine tolerances are much tighter than they were years ago and that is one of the reasons you need to use the proper recommended oil.
to put a coating in the oilways/bores could be detrimental to the oil flow around the engine.
I would agree with DaFlake's post
ps I remember that they always raised your oil pressure by quite a bit.
millers diesel additive black olive MINI Cooper Diesel 5 Aug 20th, 2008 09:49 AM
Dooper - Diesel additive? dooper MINI Cooper Diesel 13 Feb 28th, 2008 05:53 PM
Oil type and slick 50 crimprof General Discussion 3 Aug 17th, 2005 02:36 PM
Slick 50 and other engine oil additives Perm First Generation MINI Tuning 13 Aug 21st, 2003 09:54 PM
Oil Additive For New Cooper Engine Not Slick 50 but Slick 50 Synthetic? scott321172 Maintenance & MINI Care 8 Feb 13th, 2003 09:52 AM
