| changing the oil on my 2005 Cooper May 2009 I tried to change the oil on my Cooper today .. but sadly couldn't loosen the filter cap. Is it threaded normally or reverse (tighten left instead of right)? I bought a 36mm socket, but this jumbo unit + the 3/4" to 1/2" drive adapter made it too long with the wrench to fit in the limited space available. I tried with another adjustable wrench and even a nice oil filter remover that went around the entire head of the unit ... but I couldn't get the thing to budge. And I really thought I was using a lot of force... Any secrets I need to know? Thanks in advance for your feedback. Blaine Cincinnati, OH 2005 Cooper Chili Red / back roof black bonnet stripes |
| I did my 07 cooper last year and had no problem...........do you know when the filter was last off ? basically it's a plastic unit and you need to be aware of excessive force. it is a normal thread and loosens to the left. I would advise to apply a reasonable sustained force so that the rubber seal will give, ie don't expect it to move with straight away with masses of pressure. try and use the socket and apply a nominal consistent force and hold it on for a minute or so. good luck !! |
| Tags: change, filter, oil |
| Changing Gearbox Oil - Mini Cooper 06 | Jonny H | Maintenance & MINI Care | 1 | Feb 14th, 2009 11:19 AM |
| Changing oil on a Cooper S | Spectre | Maintenance & MINI Care | 9 | Apr 30th, 2005 03:36 AM |
| do i need to change oil filter when changing engine oil? | asinn | Maintenance & MINI Care | 6 | Jan 27th, 2005 05:20 PM |
| changing oil and oil filter | MINIDoo69 | Maintenance & MINI Care | 3 | May 9th, 2004 10:12 PM |
| Are you changing your oil early? | paulmon | Maintenance & MINI Care | 25 | Jan 29th, 2003 12:18 AM |
