Oil Change Help 07 Cooper S - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 29th, 2009, 10:23 PM
Local Time: 03:32 PM
I need some help here. I live 100 miles from any dealer so I'm tacklin the oil change myself. Where is the oil drain plug? I thought I had it but I believe I just drained the gearbox (black with allen wrench hold)....okay, I'm an idiot! That leads me to my second area of help....how do I fill this damn thing back up and how much oil? I see where someone recommends 75W90.
I appreciate any help.
Old May 30th, 2009, 05:20 AM
Partial answer
Okay, I just found a Utube video on how to change the oil. Lovely,.... there is NO drain plug. You gotta buy an expensive piece of equipment to "suck" it out through the dipstick shaft. Just when you thought oil changes were simple maintainence, right?
I still need help filling the gearbox back up with the oil I drained (thinking I was draining the motor oil). I do appreciate any help.
D to the G
Old May 30th, 2009, 06:37 AM
Menace Motorsport
Local Time: 05:32 AM
Australia
Houdy,
If it is a R56 cooper the oil drain bung is on the RH side of the car. (Big black pressed steel thing)
The best way to see if you have drained the eng oil is just to check the eng oil dip stick? photos would help.
tom
Old May 30th, 2009, 07:09 AM
Tom,
Thanks for your response. I swear that's the one I drained. Big Black pressed drain looking plug. Then I screwed it back in, filled the oil. It was way over full, so I said well, I need to empty some out. Unscrewed the same plug and nothing came out. That's when I realized I drained some other oil...I'm assuming the Gearbox oil.
I'll take some pics tomorrow and attach.
Dave
Old May 30th, 2009, 04:57 PM
Here are two photo's. The first is the drain plug that I think is the gearbox (Flat with allen wrench hole). I don't know what the second one is (photo 2) with the cylindrical plastic shape. Is this the oil? Does anyone know how I can refill the gearbox oil, if the first is, in fact, gearbox?
I appreciate your help.
ID:	157228   Click image for larger version
Old May 30th, 2009, 09:12 PM
oxybluecoop's Avatar
United States Male
The oil pan is the square black one on the passenger side of the MINI right next to the exhaust. The gearbox plugs are the ones in the photos so don't mess with those.
2007 MC PnP head,Cowel Induction CAI,Supersprint header/Exhaust,H&R RSS Coils/22mm sway,Alta Oil Catch,Alta Crank Pulley,AC Delete,SprintBooster,Upsolute Remap
Old May 30th, 2009, 09:46 PM
PK5
Local Time: 08:32 PM
yes i agree you have the pics of the gearbox drainplug.
Old May 30th, 2009, 09:48 PM
PK5
if you search on the website for haynes manual, you can download the area you need. you may need to register
Old May 31st, 2009, 05:44 AM
I do appreciate the help. Any idea's how I refill the gearbox. I'll search Hughes Manuals, but I had zero luck finding any kind of manual on this vehicle. It's like they don't want you working on it yourself, so they just don't allow any printing of a service manual.
Rawk on!
Old May 31st, 2009, 06:00 PM
United States Male
The plug closest to the axle is the fill plug.Takes around 1.7 litres but just keep filling until it spills out.Torque for both plugs is 43Nm. There are no repair manuals for the R56 here in the states.
Old Jun 8th, 2009, 09:08 PM
Thanks for all the help. You guys are great. Found the Oil Plug...hard to spot...near the exhaust on passanger side. Filled the Gear box back up. Back on the road!
Old Jun 28th, 2009, 08:18 PM
wow.. i just thought of changing my mini 1.4 diesel 03 reg.. is this one have drin plug or what? looked in halfords for haynes manual but only pertol mini available
Old Jun 28th, 2009, 08:22 PM
PK5
radster check haynes own website?
Old Jun 29th, 2009, 01:28 AM
Soopercooperinfo's Avatar
Local Time: 07:32 PM
United States View Soopercooperinfo's Pepper White & Black 1st Gen MINI Cooper S Profile
Here's an oil change DIY with pics for the R56 that may help in the future.
06 MCS PW/B
  #15 (permalink)
Old Jun 29th, 2009, 07:56 PM
United-Kingdom
wow good post soopercooperinfo! lots of detail there, except I'm not sure whether the people following the thread got the wrong idea and have now started changing gearbox oil rather than engine oil!
*horizontal plug is a no no, lifetime oil warranty in there*
Anyone done an early oil change on the Cooper S Ant FR Second Generation MINI Tuning 16 Feb 19th, 2009 11:21 AM
Oil Pressure Light After Oil Change tpwmini First Generation MINI Tuning 6 Apr 20th, 2005 03:50 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 05:20 PM
First oil change> Do I have to drain oil cooler ? yorobby Maintenance & MINI Care 3 Sep 26th, 2002 08:44 PM
