| Hi, all. I'm new here, so please tell me if this is not the correct forum for this post. I've searched the various Mini2 forums but can't find the answers I need, so I'm hoping someone with experience of the Scangauge II might be able to offer some guidance/clarification on the following... I just purchased a Scangauge II, and I can't get it to display any DTC info, despite the fact I've got 3 yellow warning lights.I'm guessing the lack of DTC info might be because... I'm not sure what I should do next. If anyone can offer any advice, I'd be extremely grateful. Thanks. Regards |
| Thanks, Snowie & DaFlake (dasnowieflake? )So, my understanding now, is that Scangauge II will only ever report DTC IF the "check engine" light is on and and will NOT (necessarily) show codes for any other active warnings indicators. Have I understood correctly? Snowie, I agree, my first thought was ABS or speed sensor. If a wheel's speed is undetermined, ABS couldn't work, TPS couldn't work and DSC would be out, too. I spoke to the local dealer and they want NINETY-NINE of my English pounds, JUST to run the diagnostic. Assuming this won't be the last time I see warning indicators, I reckon it's definitely worth spending £100-£300 on diagnostic tools if (as I am) you're planning on keeping your car for a while. Does anyone know of a diagnostic tool that allows us to get to the relevant systems? Cheers |
| Follow up... I just got an email from Harry @ Telematica saying what Snowie already said (SG2 won't send the ABS codes etc), but his reason for this surprised me. This is what he said: This confused me on two counts:
Any thoughts? Is the display of certain codes actually forbidden? |
| why not give modnmini a call great service and both are ex bmw with diagnostics and hopefully a bit closer to you minitorque.com, the site for mini performance, drag racing track days & time attack its all change for the S, to be revealed soon |
| Thanks, Haggi. I was just about to click SEND on an email to Tony, when I saw your post. I've sent an enquiry to modnmini (which is about 40 miles less). If that doesn't pan out, I can still email Tony. On a general note, it's really great that everyone's being so helpful and friendly. Thank you, all. |
| Just to update you, everything's fixed now. Snowie was spot on: Front left ABS/speed sensor! £22 replacement part + less than an hour's work ![]() Easy to spot with the right software - parked up on the driveway, with speed sensors on 3 wheels showing 0 MPH, but front nearside doing 158MPH!! (open circuit). Thanks for all your help |
| Yes, it seems odd. For countries that drive on the left, I guess it may be because it's not only a driven wheel, but also has a slightly tougher life - bouncing over drain covers and generally being the most exposed to splash & muck etc. But if this applies to vehicles in countries that drive on the right, I don't know... Maybe we should start a poll (if I knew how). Cheers |
| Tags: c codes, chassis codes, scangauge, scangauge ii, scangaugeii |
| Paint Code MCS R53 | The Eggman | General Discussion | 6 | Jun 1st, 2009 07:24 PM |
| Do I wait so I can get DTC? | akim47 | Second Generation MINI Cooper S | 13 | Nov 17th, 2008 10:03 PM |
| Scangauge 2 | Rigsey | First Generation MINI Tuning | 107 | May 7th, 2008 09:43 AM |
| Seat Air Bag Code R53 | Shadowman | First Generation Works | 0 | Feb 23rd, 2008 04:39 AM |
| DTC code P0456 and P1692 | mtrhere | First Generation Faults & Fixes | 1 | Sep 10th, 2007 07:33 PM |
