| TLC Help!!!!! Got an 04 cooper which had its 1st inspection serivce today under the tlc package. It had the coolant service done (anti-freeze) and replaced brake fulid. I was charged for both the parts and the labour of doing this. After paying and gettin home i found out that the labour and parts and included in the tlc package, meaing free???? Am i right or wrong on this?? also this is the first time this has been done on the car. PLeas help. |
| You get your first brake fluid change (2 years) done, but have to pay for the second (e.g. you have to pay for brake fluid change 2 and coolant 1). You've not been over charged. However, the service parts are included, apart from things such as brakes which wear. ![]() The Original MINI One Seven Yorkshire MINI Register - PM for details |
| Hi, This is the pre 2006 tlc. and includes the first inspection, and as in the manual this includes a brake fluid change if due. this is foc. But the cost of the sealant bottle that has to be replaced every 2 years is chargeable. |
| well it sounds to me that you should revisit your dealer and find out the reason why you have been charged, as on what you are telling me you have been overcharged. No reason not to ask the question! |
| You are partly right.The brake fluid is only changed if it is due to be done in accodence with the service history. So if it is not due, they do nothing. Therefore they save the cost. but if its due for a change they do it. The only thing they say thats chargable is the sealant bottle. |
| On an 04 plate MINI it will be due for its second brake fluid change which is not covered under the TLC package. Check that you have only been charged for parts and labour of the brake fluid change as all the other parts of the inspection 1 should be included with your TLC package. (not including coolet as MINIAC said) I have an 04 plate MINI which just had its oil service and 2nd brake fluid change which we paid for. The brake fluid change at my MINI dealer was around £80-£85 including liquids and labour. Were you charged much more than this? |
| No, Just the bottle your correct about the second brake fluid service not being in the tlc, But a brake fluid change is included in inspection 1 if required. So the second brake fluid service will take place after Inspection 1. |
| Changes to MINI TLC & TLC XL | Scrogg | General Discussion | 61 | Mar 28th, 2009 01:12 PM |
| Tlc | CooperS55 | Maintenance & MINI Care | 12 | Jan 17th, 2009 09:58 AM |
| Mini XXL not TLC or TLC XL but the CAR! | dieselcooperman | General Discussion | 4 | Dec 4th, 2008 03:46 PM |
| What does MINI TLC & TLC XL Cover | Solwood | General Discussion | 1 | Oct 10th, 2005 10:22 AM |
| Tlc | NeilF | First Generation MINI Cooper S | 10 | Mar 5th, 2004 03:40 PM |
