Low Water - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 13th, 2009, 08:06 PM
Local Time: 07:46 PM
Low Water
I checked my oil today and noticed it was low so topped up but also noticed water was nealrly completely empty. Can I just mix coolant and water and top up?
Old Jun 13th, 2009, 08:08 PM
PK5
how low is the coolant?
Old Jun 13th, 2009, 08:10 PM
thick brown glug at the bottom of the bottle but temp gauge normal
Old Jun 13th, 2009, 08:12 PM
PK5
on the bottle ther should be 2 lines one reading low the other high. you can add water to the max and when car goes in for next service or a winter check whichever comes first ask dealer to check density of coolant.
Old Jun 13th, 2009, 08:15 PM
It will be going in for a service in about 6-8 weeks. Do I top up with just water or water/coolant. Thanks for your help. I dont have a clue!!
Old Jun 13th, 2009, 08:17 PM
PK5
water will be sufficient just keep an eye on the level if you have to top up again before service take to the dealer for the service early.
how low should i go softtoptel First Generation MINI Suspension 11 Apr 1st, 2008 07:58 PM
Water damage to engine - air intake susceptible to sucking in water stevesok First Generation Faults & Fixes 83 Jul 25th, 2007 04:58 PM
how low can u go ?!? charliefummi First Generation MINI Cooper 1 Sep 16th, 2003 10:38 PM
How low can I go..? JonBlakeburn First Generation MINI One 10 Aug 6th, 2002 08:05 AM
