| A failed oxygen sensor should produce a fault code and turn on the malfunction indicator light (often called, confusingly, the “service engine soon” light). Marginal operation of the sensor could affect mileage and not cause the light to be turned on, but there may be a pending code set and a decent scan tool should show this status. A good oxygen sensor produces an oscillating waveform that toggles between 0.1V to 0.9V. The sensor indicates between 0.1V for lean mixture and 0.9V for rich air to fuel mixture. The OBD2 tests how fast or slow the oxygen sensor transitions between lean and rich mixture levels (usually referred to as “crossings” as the voltage crosses the nominal mixture value) and compares the response time of the oxygen sensor with known good values. More comprehensive OBD2 scan tools will also display the oxygen sensor output waveform as seen using an oscilloscope, or a high impedance volt meter across the sensor will show the activity. The oxygen sensor compares the oxygen levels in the exhaust with the outside oxygen level. If the sensor is coated with mud or undercoating then this will cause it to mis-read. Note that I am referring to the sensor before the catalytic converter. The post-cat sensor is there to monitor the effectiveness of the catalytic converter and its failure will not affect the engine operation. |
| I did have a "service engine soon" light appear the fault code reader gave me this : P2096 Post catalytic converter fuel trim , bank 1 - too lean the light would come on intermitenly off and on, I would clear it and re check and it gave me the same error code, after about 10,000miles its has gone off and not re-appeared. To be honest I havent check to see if theres a error code still there. Again the fule mileage dropped right after this was starting to happen so if the o2 sensor stops working completly does that trigger another "service " light? |
| The P2096 code relates to the post catalytic converter oxygen sensor and shouldn't affect the milage. I believe that it is set after the sensor reaches its operating temperature when the system runs a monitor (test) to determine if the post-cat sensor is working. The P2096 code is a lean condition and this should not result in reduced milage, unless the system enriches the mixture to correct the condition! That would be the tail wagging the dog as the pre-cat oxygen sensor is the one that should control the fuel/air mixture. I would scan the system and see if there are any fault codes or pending codes stored Monitor the oxygen sensor output if you can and see how it's operating. It is possible that the pre-cat sensor is faulty, but there are many other faults that cause low milage. I think too many oxygen sensors are changed unnecessarily and often see the "service engine light= replace oxygen sensor" advice given without any diagnostic work. |
| Fuel Question | Cobers Vxr | General Discussion | 18 | Jun 4th, 2009 07:58 AM |
| Fuel Question | MINI-Bob | General Discussion | 4 | Nov 24th, 2007 09:19 PM |
| gas mileage during break-in - 33mpg in town? also, a tire question | pspsps | First Generation MINI Cooper | 1 | May 31st, 2004 10:19 PM |
| Gas Mileage Question | MiniLine | General Discussion | 2 | May 10th, 2004 04:13 PM |
| JCW 'S' Fuel Question | duncs | First Generation MINI Cooper S | 14 | Sep 4th, 2003 03:56 PM |
