Think Mini
Old Oct 23rd, 2002, 02:46 PM   #1
jlm
Local Time: 05:03 AM
gearbox/trans-axle oil change
anyone done this for the S 6 speed?
forum search found nothing.
john
Old Oct 25th, 2002, 06:44 AM   #2 (permalink)
jlm
bump?
john
Old Oct 29th, 2002, 03:12 PM   #3 (permalink)
sbuppert
Wink
My S was shifting a little more stiffly than I thought it should, so I changed the transaxle lubricant......and it was a wise move as the level of lubricant was only just over half of what it is supposed to be. it was underfilled by almost 3/4 of a quart. the drain plug and fill hole are readily accessible from under the car and the whole process only took about 15 minutes.
Old Oct 29th, 2002, 04:29 PM   #4 (permalink)
ezrally
ezrally's Avatar
Local Time: 04:03 AM
How much did it take about/what brand & weight did you put in?
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
United States View ezrally's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 29th, 2002, 05:12 PM   #5 (permalink)
sbuppert
It took about 63 oz. or just under 2 qts. to fill it and I used Redline MT-90.......and the ease of shifting has improved.....it is less notchy......MT-90 is the recommended weight for the 6 speed Audi TT which also uses a Getrag transaxle......the Redline is expensive at $8 per quart......but, is recommended as the best available.........I also use it in the transmission and differential of my Chrysler Conquest TSI and the shifting is better and the car is definitely, though only slightly, faster......
Old Oct 29th, 2002, 05:39 PM   #6 (permalink)
ezrally
ezrally's Avatar
Yep, Redline does work good in Mitsu cars (Galant VR4 here )
Wonder why your S was low...hope they all aren't.
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
Old Oct 31st, 2002, 01:13 PM   #7 (permalink)
jlm
yep, 15 minutes. takes an 8mm hex key and a funnel with about a 2' long 1/2" hose to re-fill. that is a very cute little trans and axle.
mine had about 1.5 qts in it and took just under 2 qts to re-fill with the Redline MT 90.
john
Old Oct 31st, 2002, 01:57 PM   #8 (permalink)
ezrally
ezrally's Avatar
Hmmm, another low one...
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
Old Nov 2nd, 2002, 11:05 AM   #9 (permalink)
Bibendum
I've been thinking about this as well because my gerbox is 'notchy.' Got a few questions thiough. Is it written down some where or can you tell me where you found out the what the gearbox lube requiremnts are? Amount? Did you assume you fill to the fill plug level? I like Redline as well, but why not MTL not the 90wt? Are there crush washers on the drain and fill plugs? Torque values?
Many thanks
Bibendum
Old Nov 2nd, 2002, 12:06 PM   #10 (permalink)
MoMini
From what I've read the MTL was formulated to ease shifting of BMW trans in cold weather. I am not that familiar with Redline products, is their MT90 equivalent to the standard 75W90 weight gear oil? Mobile makes a synthetic version that I was thinking of using...any reason not to? Thanks
Old Nov 4th, 2002, 12:23 PM   #11 (permalink)
sbuppert
The Redline technical dept advised as to the recommended lubricant for the Audi TT 6 speed Getrag transaxle....as for the other questions, it would make sense to call the tech dept.......the number can be obtained from any Redline dealer....or off the internet.......The Mini owners manual only gives the capacity of the transaxle.....nothing more..
Old Nov 4th, 2002, 10:01 PM   #12 (permalink)
jlm
i used a set of ramps; you could do it without if you were thin enough to slide under...or figure how to put the front wheels up on a curb to get a few inches more clearance
the drain plug is on the bottom of the diff housing, the fill about 3" higher, you need a 8 mm hex. to refill, i used a funnel with a 1/2" hose and fished it down from the engine compartment stuffing it into the fill opening.
john
Gearbox oil change on Mini One Adam858 Faults & Fixes 5 Jul 1st, 2007 08:41 PM
Gearbox oil change Q on an S ezrally Maintenance & MINI Care 0 May 7th, 2006 04:57 PM
gearbox/trans issue The_length Faults & Fixes 1 Mar 6th, 2006 10:48 PM
Oil Pressure Light after Oil Change tpwmini Faults & Fixes 0 Apr 16th, 2005 03:46 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
