How to clean/polish 06 MCS exhaust tips? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 30th, 2009, 07:23 PM
quentinberg007's Avatar
Send a message via AIM to quentinberg007
Local Time: 07:32 PM
United States Male
I noticed the exhaust tips on my wife's MCS look terrible. There is quite a bit of rust at the bottom of the tip (where water trickles out when you've shut the vehicle off). What are my options for cleaning/polishing them? Can I replace them? Am I going to have to buy a new backbox? I'll try to get a photo to show the condition.
Old Aug 30th, 2009, 07:41 PM
United States Male
Pic:
Old Aug 30th, 2009, 08:15 PM
The Eggman's Avatar
Local Time: 01:32 AM
United Kingdom Male View The Eggman's Dark Silver & Black 1st Gen MINI Cooper S Profile View The Eggman's Classified Ads
I just use metal polish on a JCW system.
Old Aug 30th, 2009, 10:59 PM
Local Time: 12:32 AM
United Kingdom View Sooper Rob's Classified Ads
Had a similar problem. With metal polish (Autosol is good) and lots of patience, I achieved good results
Old Aug 30th, 2009, 11:21 PM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
If that fails you can get new tips from a dealer. The old ones are secured with an allen key type bolt. Remove and keep this (may need wd40 to make it undoable!) slide the old tip on and replace with the new one. Then reattach the bolt and tighten
Job done - takes minutes!
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Aug 30th, 2009, 11:55 PM
United States Male
Thanks, guys! Off to apologize to the wife (I jumped on her about not letting me know they were getting surface rust in the first place.)
Old Aug 31st, 2009, 08:12 AM
still learning
Scotland Male
also don't forget to wash them when you wash the car.........yours look a bit neglected tbh
Old Aug 31st, 2009, 11:05 AM
Quickest way to sort that is to get in there with a small-ish paint brush and a bit of either silver or black hammerite. Up to you if you trust yourself enough to do it without masking the surrounding chrome or just go in there free-hand.
The other ways mentioned above will work as well. But I'd guess the cost will be higher. If you buy a replacement tip then the same thing will happen to that one unless it's made of high-grade stainless.
Personally, not a massive fan of the standard cooper tip. Would be better to have anything else sticking out there... the JCW tip is probably my fav at the moment.
Old Aug 31st, 2009, 12:38 PM
MINI One Seven
Paint it That would look ridiculous! Follow rob's instructions or get new. Once you have new ones, wax them and keep them clean and this shouldn't happen! Most don't do this
Old Aug 31st, 2009, 04:37 PM
I think you're just missing the point a bit.
Need to paint the rusty bits inside the tubes past the lip at the edge. Not the outside! The outside needs a bit of a clean but will tarnish again soon enough anyway.
I'd probably choose black rather than silver.
Old Aug 31st, 2009, 05:03 PM
MINI One Seven
You said exaust tips - to us that means the chrome tip. If you mean the pipe say how to clean the pipe! Just get some autosol that should do it. Infact that'll do the tips as well. Simple! Although I can't understand how it gets rusty in there - I don't clean mine, and in 3.5yrs mine has no rust there...
Old Aug 31st, 2009, 05:22 PM
depends on how much condensation your type of driving generates. Personally, as I'm a bit of a lead foot... I'm sure much of the condensation in my exhaust gets spat out at high velocity and gets no chance to hang around. Possibly the way you store you car might also have something to do with it as well. If you store on a level drive or road facing the sun then that would be better conditions for making rust than facing downhill in the shade.
Tags: , , ,
Retro fitting JCW exhaust tips to MCS Exhaust Cooooooperslad First Generation MINI Exterior 14 Dec 19th, 2010 07:26 PM
Replacement tips for MCS exhaust CooperS55 First Generation MINI Exterior 7 Sep 9th, 2008 11:37 AM
mcs exhaust tips ive had fitted checkmatechris First Generation MINI Cooper S 8 Sep 7th, 2007 12:06 PM
What's the best way to clean exhaust tips? Milquetoast Maintenance & MINI Care 4 Jul 15th, 2003 12:11 PM
