Help refilling coolant - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 4th, 2009, 08:17 PM
Local Time: 06:32 PM
Hi, my wife's Mini started overheating last evening. I checked and the expansion tank was bone dry. I added coolant to the expansion tank - to the MAX level. I drove it for a while and it started heating up again. I checked under the hood again and the expansion tank is still full to the MAX level. I am afraid there might be an air bubble in the hose so it isn't pulling in the coolant. How do I bleed the tank or "prime" it if that makes sense?
Old Nov 4th, 2009, 10:26 PM
minimattsback's Avatar
Going up in the world
Local Time: 01:32 AM
Attached is the procedure for draining and adding coolant. This is from the Mini Maintenance Manual. Hope this helps.
ID:	158604   Click image for larger version
ID:	158605   Click image for larger version
Old Nov 7th, 2009, 08:44 AM
Local Time: 12:32 AM
Wales
Thumbs up
I need to top up my coolant for the winter and wouldnt have followed that procedure so thanks MMB!
Where is my coolant going ? Jordan210 First Generation Faults & Fixes 9 Jan 6th, 2008 10:15 PM
What coolant should I use? fergusor First Generation MINI Tuning 3 Jun 11th, 2007 09:21 AM
Coolant dreamydaniel Maintenance & MINI Care 2 Sep 4th, 2006 09:30 AM
Using other coolant on MC? elmadi Maintenance & MINI Care 0 Nov 19th, 2002 01:15 PM
