Topping up Coolant with water??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 29th, 2002, 01:27 PM
Local Time: 01:42 PM
United States View elmadi's Liquid Yellow & Black 1st Gen MINI Cooper Profile
My dealer said I could top up my coolant with water.
Does anyone did this already?
Thanks.
Old Oct 29th, 2002, 01:32 PM
COOPERation's Avatar
Local Time: 03:42 PM
Better hope the weather doesn't suddenly turn COLD....water freezes!
Old Oct 29th, 2002, 01:44 PM
HarryHBMCC's Avatar
Local Time: 02:42 PM
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Arrow
If you just need to add a little then water is OK but if you must add a lot (more than a few ounces) then you'd better add a proper coolant mixture.
If your car is a little low, perhaps a leak check is a good first step? If they can't find anything then a top up is all you can do.
Harry
Old Oct 29th, 2002, 01:54 PM
BruceK's Avatar
Moderator & Sponsor
If you're going to add water, it's much better to use pure, distilled water. You don't want unnecessarily add minerals from tap water or bottled water that could harm the cooling system.
Old Oct 29th, 2002, 02:58 PM
Thanks for the input.
How about "boiled water",is it okey?
Old Oct 29th, 2002, 03:01 PM
Harry
Thanks.
If I will add a proper coolant mixture, should I buy the 'coolant" at the Auto Store like "Preston" or should I bring it to the dealer for them to fill it up??
Old Oct 29th, 2002, 03:06 PM
Apial's Avatar
Local Time: 07:42 PM
United Kingdom Male View Apial's Lightning Blue & Silver 2nd Gen MINI Cooper Diesel Clubman Profile
If you live in a "hard" water area, then use some melted frost from the freezer. Soft water areas should be better. The trouble with hard tap water is that each time you add it the insoluble calcium deposits build up and will block the rad matrix. This might take a few years of topping up, but why do you need to top up? If there is a fault you will continue topping up until you do block the system.
Old Oct 29th, 2002, 03:20 PM
HarryHBMCC's Avatar
Your owner's manual should state the requirements for coolant. You can buy it yourself premixed (recommended) or mix it yourself.
As I said above, if you haven't been to the dealer for this problem yet it would be wise to take it in for a look-see. They will likely top it up for free as part of their inspection.
Harry
Old Oct 29th, 2002, 03:28 PM
I had my MC for only 3 weeks, 540 mile only.
I notice the coolant level is now "between" MAX & MIN.
I do not know if I should top it.
Old Oct 29th, 2002, 03:38 PM
HarryHBMCC's Avatar
Arrow
About halfway between MIN and MAX when the engine is cold is normal and doesn't require topping up. If it is right at or below MIN then you should be worried.
Harry
Old Oct 29th, 2002, 04:01 PM
Harry
Thanks Harry.
Old Oct 30th, 2002, 12:16 AM
Canada View thegrommit's Indi Blue & White 1st Gen MINI Cooper Profile
I assume you're referring to the level in the clear plastic "coolant expansion reservoir"? As Harry said, it's normal.
Old Oct 30th, 2002, 08:50 AM
BruceK's Avatar
Moderator & Sponsor
Buying a gallon jug of distilled water at your local grocery store or WalMart (only about $1) would be a lot easier than harvesting any freezer frost.
Boiling water won't do at all. It simply kills bacteria and leaves all the minerals intact.
Get the distilled water.
Old Oct 30th, 2002, 09:32 AM
HarryHBMCC's Avatar
In fact, boiling takes the water out and leaves a higher concentration of minerals. If you boil it right down you'll get a white residue which is the stuff you'll leave in your engine by using tap water.
Harry
  #15 (permalink)
Old Oct 30th, 2002, 09:42 AM
Thanks Bruce. I forgot those distilled water at WallMart--way,way cheaper!
Water damage to engine - air intake susceptible to sucking in water stevesok First Generation Faults & Fixes 83 Jul 25th, 2007 03:58 PM
What coolant should I use? fergusor First Generation MINI Tuning 3 Jun 11th, 2007 09:21 AM
Topping up the oil level crimond Maintenance & MINI Care 8 May 29th, 2007 08:54 AM
AAAGH! Water in coolant expansion tank Maccaloon First Generation MINI Tuning 2 Sep 14th, 2004 11:48 AM
Topping off the coolant scottwkurth Maintenance & MINI Care 3 Dec 11th, 2002 10:12 AM
