BMW say 30,000 miles between oil changes. Is this safe ? - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Mar 20th, 2010, 02:01 PM
Local Time: 08:42 PM
United Kingdom Female
Quote: Originally Posted by KenL (original)
Was the oil change counter reset when you changed the oil?
If not, I think the MINI has a way of testing the oil to determine how long it will be until it "requires" changing.
My MCS is predicting an its first oil change at ~20k or two years after it was built 10/08.
No, it wasn't reset, it's been suggesting about 27k miles for the first change since it was about 6mths old. I do mostly fast A road and motorway miles and I think it took that into account. It is supposed to take driving style into the calculations. A reset would have messed with the TLC service so we decided not to.
My cars are oil changed every year, even the little Honda which never does more than 1k miles per year!
  #17 (permalink)
Old Mar 21st, 2010, 04:12 AM
Local Time: 11:42 AM
United-States have the oil changed
Read yuo user guide. (I did not) You should have your oil and filter changed at least yearly no matter how many miles you have driven it. At least that is what it says here in the USA. Other things should also be done yearly. It should be covered under your Maintenance Warrenty.
  #18 (permalink)
Old Mar 21st, 2010, 08:26 AM
I just wanted to thank everyone who has replied for their comments . It is reassuring to see that you all agree with me and all point out that it's an unacceptable risk to leave the engine oil unchanged for so long . I will contact the garage and refer them to this thread . Regardless of their response I will make sure that the oil gets changed. Thank you all.
Dave
  #19 (permalink)
Old Mar 21st, 2010, 10:38 AM
GP 1699
England Male View R53 Cooper S's Classified Ads
the r53 calculates the service interval by fuel consumption.
the more fuel it uses the more load is on the engine therefore the service interval will be shorter. 15k max between services when you drive them steady is normal!
  #20 (permalink)
Old Mar 21st, 2010, 11:20 AM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
On UK cars its 2 years or when the service counter reaches zero. Which ever is sooner
Interesting that the interval is only one year in the USA mind...
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Oil Pan Gasket Fails at 33,000 miles GPH First Generation Faults & Fixes 3 Mar 18th, 2008 03:47 PM
10,000 miles! jimmy_racoon Maintenance & MINI Care 12 Sep 27th, 2005 12:17 AM
WARNING - When is 10,000 Miles NOT 10,000 Miles ??? Bear Maintenance & MINI Care 14 Jul 16th, 2004 10:39 AM
Approaching 10,000 miles- 1st oil change? MINIRANDOLPH General Discussion 4 Sep 2nd, 2003 07:34 AM
20,000 Miles! Vanwall General Discussion 3 Mar 30th, 2003 08:18 AM
