| Spark plugs, engine coolant and the serpentine drive-belt. I've got a 2003 MINI One same colour as yours with 86,000 miles. I'm going to change the gearbox oil and lubricate the gear linkages this month. |
| Are you on the original steering pump, if so you have done very well and it would be a good idea to at least remove it and clean out the carbon dust inside the motor or maybe to replace with a recon unit as a precaution against future failure at an inconvienent time. Also change the gearbox oil and clean the magnetic drain plug to extend gearbox bearing life. Both easy jobs and not that expensive if you DIY or avoid the BMW main dealer type garages. |
| Tags: high mileage, maintenance, mini one, r50 |
| Brake info parts request and Specialist in Birmingham | Ilogik | First Generation MINI Cooper | 6 | Dec 28th, 2009 02:52 PM |
| Request for info. | j.nathan | UK & Ireland Discussion & Event Planning | 2 | Sep 17th, 2003 07:52 AM |
| Request info about SNOW and your mini.... | Gryphon | General Discussion | 20 | May 10th, 2003 02:51 AM |
| Updated hatch latch info request | CurtP | First Generation Faults & Fixes | 12 | Mar 10th, 2003 12:59 PM |
| Info Request - Changing Speakers | bennyboy | First Generation Interior & Ice | 4 | Oct 11th, 2002 06:10 PM |
