Rear Brake pads & discs replacement - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 10th, 2011, 01:45 PM
Local Time: 08:44 PM
Hi all,
Had my R56 cooper S serviced, and according to the service man, one of the rear brake pads need to be replaced.
Unfortunately both rear brake discs & pads will have to be replaced as well.
Can anyone recommend a 3rd party make? I suppose it'll work out cheaper getting them and having someone else fit them ?
Old Mar 10th, 2011, 07:41 PM
Hi
one of my mates just had his done at bmw i think it was a fixed price job £189 i think for rear discs and pads and fitting not to bad for oem parts and time and peice of mind
if you go aftermarket becarefull what you go for, you dont want to make the brakes to good on the rear or it could unsettle the car under braking and could be abit hairy in the wet or ice
if i do servicing bit for my self i use GSF the shop near me the guys are very helpfull and as far as i have been told it OEM part but not in BMW boxes, then find a good mech near you but check out his hourly rate first before buying anything
gsfcarparts.com
hope this help
Tags: , ,
replace new rear brake pads & discs on a R56 tom73 Maintenance & MINI Care 6 Feb 20th, 2010 01:45 PM
USA - replacement brake pads ad discs oopsdy Wheels, Tyres & Brakes 2 Nov 12th, 2008 11:28 PM
Replacement Pads and Discs theone Wheels, Tyres & Brakes 0 May 9th, 2006 04:21 PM
new alloy and tyres will i need to get new brake discs and brake pads TREBALZ Wheels, Tyres & Brakes 7 Sep 23rd, 2003 11:24 PM
