| Brake caliper dust Seal I am doing a complete brake job on my '03' MINI Cooper S and I will be having the calipers powder coated. I can not figure out how to get the dust seal off without destroying them. I need help... |
| Consider just replacing... If you are powdercoating, I expect the calipers must be off the car. I expect you would want to pull the pistons too and then block the cylinders and all the other openings. Mini likely sells a rebuild kit that should give you a new piston seal as well as outer dust seal. When I have bought those for Audis, they are usually pretty reasonably priced, plus then your caliper is serviced internally as well for much longer problem free life. |
| im also experiencing the same problem by the why do we need a special tool to remove this stuff from our mini? by the way mp1 where did you purchase such kit? please give me some sites where i could order one. thanks. (please do not suggest eby or amzon) Last edited by rsmith; Oct 15th, 2011 at 02:56 AM. |
| Tags: brakes |
| Caliper Dust Seal | wayne_crowther | Wheels, Tyres & Brakes | 2 | Feb 13th, 2011 11:08 AM |
| Problems with crankcase seal, brake disks and brake pipes | gmordue | Maintenance & MINI Care | 1 | Jan 6th, 2009 07:57 PM |
| Brake Caliper Paint? | Tara&Paul | Wheels, Tyres & Brakes | 15 | Oct 7th, 2008 06:12 PM |
| Brake Caliper | Posts001 | Wheels, Tyres & Brakes | 4 | Apr 9th, 2008 09:10 PM |
| Brake caliper colour | the-ruff-puppy | First Generation MINI Exterior | 15 | Jul 18th, 2006 02:58 PM |
