Exhaust patching - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 11th, 2011, 05:05 PM
Local Time: 07:44 PM
United Kingdom View Zwilnik's Indi Blue & Body Color 1st Gen MINI One Profile
DIY Exhaust patching
At its last MOT in November, my Mini One was noted as having some corrosion around the end of the exhaust, Kwik Fit also commented on it when they replaced the brake pads and said it wouldn't be an MOT issue or problem as-is, but was worth patching to avoid it getting worse.
Here's a pic of the problem area..
I'm guessing that the various Holts exhaust bandages etc. could be used to patch this once it's been cleaned up with a wire brush? and in theory should be good enough to the next MOT rather than replace the exhaust.
This would be my first proper bit of DIY on my Mini, so thought it would be a good plan to ask about first
Old May 12th, 2011, 06:50 PM
Tigger, Eeyore & Roo's Avatar
Focus RS & Land Rover FL2
Online
Local Time: 08:44 PM
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile View Tigger, Eeyore & Roo's Classified Ads
Exhaust bandages and their like are nothing more than a short term bodge to either bluff your way through an MOT or fix up a banger with a view to a rapid sale!
Nothing you can do is going to slow down the structural disintegration of that silencer, as the corrosive gases and liquids in the exhaust gases will inevitably rot the silencer from the inside out.
Save your money and put it towards the inevitable new silencer when it finally blows....
May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered...
Tags: , ,
Retro fitting JCW exhaust tips to MCS Exhaust Cooooooperslad First Generation MINI Exterior 14 Dec 19th, 2010 07:26 PM
JCW R53 Exhaust Piece (Exhaust Pipe Extension) R53 First Generation MINI Exterior 2 May 17th, 2009 05:45 PM
JCW GP Exhaust on Mini One(dyno inside without\exhaust) Innuendo First Generation MINI One 13 Feb 25th, 2007 10:15 PM
Patching up a roof, is it possible? Snoogans First Generation MINI Exterior 2 Nov 10th, 2006 09:30 AM
