Cam Chain Tensioner? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 3 (permalink) Old Jul 3rd, 2011, 02:06 PM Thread Starter
Stig
Potter's Avatar
Local Time: 07:35 AM
Hi guys i have got a 52 plate Cooper S and have had a lot of tapping noises coming from head over past few days when engine is NOT underload but is fine when it is under load.
Anyhows after removing all of the intercooler and and rockercover i am aware that the Chain is quite a bit slack and i need to Buy a Cam chain Tensioner....but was wondering if any of you guys know where to get one from and how much they are??
Cheers Luke
Potter is offline
post #2 of 3 (permalink) Old Jul 3rd, 2011, 06:40 PM
POP..POPPOP..POP
tnoy66's Avatar
Local Time: 06:35 AM
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
They're about 30 from your dealer.
RealOEM.com BMW R53 Cooper S Timing and valve train-timing chain
Down back of engine and a 19mm offset ring spanner is your best bet for getting it out.
Can be done from working above or remove O/S wheel and arch liner.
I'd recommend changing the oil and flushing engine too.
The new one comes compressed and once fitted the oil pressure extends it forward and tensions the chain
tnoy66 is offline
post #3 of 3 (permalink) Old Jul 3rd, 2011, 08:35 PM Thread Starter
Stig
Potter's Avatar
Cheers mate
Potter is offline
Fitting a New Timing Chain Tensioner Vinnie First Generation Faults & Fixes 5 Oct 25th, 2013 03:57 PM
Hydraulic Chain Tensioner Fail Fixed djshoo First Generation Faults & Fixes 0 Apr 25th, 2011 10:49 AM
R53 MCS timing chain tensioner replacement Bimba Maintenance & MINI Care 0 Mar 13th, 2011 01:41 PM
Engine Mount Leak + Timing Chain & Tensioner Failure Puma Second Generation Faults & Fixes 2 Mar 26th, 2010 05:01 PM
