What is the correct tyre pressure for 205/40r/18 runflats?
Hi just wondering what the correct pressure is for these tyres, they are bridgestone 205/40r/18 runflats, currently i run them at 34PSI but i'm not sure this is correct.
Did you look on the driver's side door jamb? Mine says 38 psi cold. I have the 205'45'17 run flats. I'm running about 35psi as I believe the 38 psi is a maximum pressure.
Front and rear pressures should be separated. The third is for the spare, which should be blank because you probably don't have a spare with run flats. Mine shows the same pressure for the front and rear.
