my 2004 mini one gearbox - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 3rd, 2011, 07:42 PM
Local Time: 07:44 PM
just need peoples opinions . i need a new gearbox for my mini one the guy at the garage has asked me if i want the clutch doing aswell . what is the right option i should take all opinions greatly received . thanks
Old Nov 3rd, 2011, 07:51 PM
mab01uk's Avatar
Local Time: 08:44 PM
Always worth replacing clutch at same time in my opinion unless it is very recently replaced or hardly worn, as a similar amount of labour and dismantling work is required to swap the clutch or gearbox. Not something to risk repeating twice. Clutch parts kit is around £150.
Old Nov 3rd, 2011, 07:59 PM
thanks for that , think i will replace both.
Old Dec 21st, 2011, 08:14 AM
bjp
Wales
lynnhusky, seems like im in a similar situation with my 04 mini. My garage informed me after a service a few weeeks ago that my gearbox needs a recon. They quoted £600 to recon the gearbox and replace the clutch. What ballpark prices have you been quoted???
Old Dec 21st, 2011, 11:46 AM
mab01uk's Avatar
£600 seems like a good price, make sure you get a gearbox with a reasonable warranty included.
This company is a popular choice:
http://www.minigearboxes.co.uk/
Old Jan 4th, 2012, 02:07 PM
United Kingdom Female
Silver Black Joining the club - forced to change my 5-speed Getrag gearbox
So my original post was this -
I'm really sorry if this thread is solely linked to MCS's - I can't find a thread for my Mini One but I have a very similar issue. Advice would be greatly appreciated.. or redirection!
Mini One 54 reg, 46000 miles. Owned almost a year.
When I bought the car, no fluttering/ticking/paper in spokes sound. In the past few months, this has started occurring every time it's driven.
Doesn't matter if the car is idling, in gear, out of gear, gets gradually louder the faster I go and speeds up with the wheel rotations. I've tried taking out of gear also whilst travelling at varying speeds (loudest from 50mph+ and around 3000rpm) and it's still happening hence my diagnostic of wheel speed rather than engine speed. Regardless of whether clutch is in or not.
The sound itself is driver's side footwell to centre console. And is extremely irritating. Would like to know what it is so it can be fixed, I can check if anything more serious and so it's back to normal!
The heatshield has been tightened, there is a connector loose at the front of the engine bay which has been taped up, another part which the rubber had come loose from its housing - all put back together, wheel arch has also been checked and tightened. But still the sound happens.
It's been in the garage recently as had to have the 02 sensor changed, but they said they couldn't see anything it could be.
I'm wondering - could it be something to do with the crankshaft pulley / harmonic damper? Is there anything else which is common in these?
Thanks in advance.
However since posting that a week or so ago, the noise is worse, the car although still drives is not being driven (as I'm **** scared it's going to stop) and I'm now on the path to getting the gearbox changed. D'oh!
Fluttering noises got louder and louder.. and when checking the diff, it clicks (car up on jack). Have spoken with both MiniMatt and minigearboxes.co.uk as well as checking on the forum... it seems I have one of the famed, dodgy Getrag 5-speed gearboxes. The design is apparently not the best, with the diff not fitting the gearbox as it should (think that's what I was told).. and the diff click is due to the bolts.
Mini themselves were YET AGAIN absolutely useless and only interested in making a few quid, so am taking to reputable, recommended people now that don't rip me off.
Fingers crossed getting a refurbed gearbox, replacement clutch, fitted + VAT for about £1300. Comes with 12 months warranty/12000 miles. They will do in a day and collect/deliver the car back to me. Sounds good to me.
Is this price ok?
Old Jan 4th, 2012, 05:19 PM
Cooper S Jon's Avatar
Smile
http://www.mini2.com/forum/first-gen...x-ticking.html
thought the 5sp was the midland box,getrag was the 6sp fitted in the 2nd gen minis
still learning so could be wrong<< which i am,.there is a 5 sp getrag box
I'd rather push my mini than drive a ford or anything french..
Criteria for buying a diesel..1)long journeys.2)motorway miles.3)minimum 14k mls per yr..
Old Jan 4th, 2012, 05:34 PM
Hi
Have a look at this link might be of help lot of good info
MINI Cooper Forum - MINI2 Mini Cooper Forums - FAQ & DIY: General MINI FAQs and Advice
Old Jan 4th, 2012, 05:58 PM
mab01uk's Avatar
The price you have quoted above seems reasonable for a Mini gearbox/clutch job.
Old Jan 4th, 2012, 06:01 PM
mab01uk's Avatar
Rover Midland box is early pre-facelift 5-speed One/Cooper, Getrag 5-speed is post facelift (mid-2004) One/Cooper and MCS has always been a 6-speed Getrag.
Old Jan 4th, 2012, 10:29 PM
Looks like I have one of the earlier 5 speed Getrags to be put in.
Mine is a 54 reg, registered/built Jan 2005.
Car is being taken tomorrow to be fixed ... will feedback Fri eve/Sat when I have the car back... FINGERS CROSSED! I'm going to minigearboxes.co.uk.. so far happy with the conversations and info I've received, so she's all booked in
Thanks for your help!
Old Jan 10th, 2012, 01:56 PM
bjp
Wales
lisajayne86, I had all the problems you mentioned with my Nov 04 mini, 79000 mines. Have had the gearbox reconed and new clutch in the last week which cost £780. All the associated problems have gone since and it drives really well.
Mine had a getrag gearbox in it which the garage were a bit surprised by when they took it apart, but it would seem the Getrags are not a solution to the original crap gearbox problem.
Good luck!!
Old Jan 15th, 2012, 09:10 PM
Gearbox replacement
Hi all.
Totally forgot to feedback re: the fix on my 54 One.
The more-than-a-little-annoying fluttering sound has disappeared
The feedback I got was that had I not taken the decision to stop using my car, and driven approx 10 more miles, the gearbox would be no more. The bolts had come out of the differential and it would have gone bang. Phew!
Ended up spending £1260 = this included refurbished gearbox with 12 months warranty/12000 miles; labour to replace; VAT; new clutch; £400 surcharge on my old 'box as it was in such a state.
Fingers crossed it's ok now!
mini gearbox miles250 First Generation Faults & Fixes 1 Oct 2nd, 2009 07:37 AM
BMW mini gearbox frowner1 First Generation Faults & Fixes 1 Jun 6th, 2009 05:38 PM
Mini Gearbox gadavies First Generation Faults & Fixes 8 May 22nd, 2008 01:47 PM
Cooper S New gearbox 2003 or 2004 Pglenning First Generation MINI Cooper S 3 Oct 25th, 2006 10:27 PM
