Hi guys I have a engine overheat and no heat in the cabin problem. Researched the forum and want to try bleeding the airlock in coolant system.
I found 2 bleed screws as shown in the pic, but I can't find the third. It supposed to be a 8mm small one, and on the "heating distributor pipe“. But I don't know what is the heating distributor.
Could someone point out on the pic plz?
Also is the filler cap I marked in the pic the correct cap where I fill in the coolant?
It say not manual tightening, 16 lbs toque is needed. Is this strict?
Thanks a lot for your help?
