Oil Leak from Oil Pan area. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 7th, 2012, 02:47 PM
Local Time: 08:45 PM
United-Kingdom Oil Leak from Oil Pan area.
Hello,
I hope someone can help. I seem to be suffering from an oil leak. So over Christmas I set about the task of changing the Oil Pan Gasket. All parts are genuine from Mini. Whilst doing this I also changed all the engine mounts and super charger damper bushes to Polyflex bushes. I also replaced the fan belt, PCV valve, oil and filter.
Car currently has 35k on the clock and is a Mini Cooper S JCW.
After replacing the sump gasket I was hopeful that the oil leak was resolved, however it seems to be back.
The front of the engine is completely dry so its not the crank sensor. The left hand side of the engine is also dry so I'm sure its not the crank seal on the left. The actual Gasket around the sump also appears to be intact and dry. So I am pretty much at a loss.
I have read that the transmission bolts are generally over torqued which is why I waited a week and torqued them up a small amount more. This has actually created more of a leak.
Here is a picture of my baby:
now pictures of the oil leak:
Now I am open to any suggestions, and would appreciate any help.
Thanks in advanced.
Old Jan 7th, 2012, 11:08 PM
Hi
Looks to me like if I have the pictures correct in my mind the crankshaft oils seal behind the flywheel :-(
my one weeps now and again. when I do my clutch and fly wheel it's going to be replaced
But I would also say check you gear box oil make shore that's ok as well
Old Jan 8th, 2012, 10:54 AM
Quote: Originally Posted by marque (original)
Hi
That is my worst fear.
But one thing that leads me to believe that is not the crank seal is that fact it now seems to leak more after adding slightly more torque to the transmission bolts.
If it is the crank seal, is there a risk of oil contaminating the clutch?
Tags: , , , ,
Help, oil leak from power steering pump area kirsty2010 First Generation MINI Cooper 0 Nov 21st, 2011 05:56 PM
Radiator leak, Engine Mount leak classed as wear and tear or mechanical fault? alag20 First Generation Faults & Fixes 8 Jul 2nd, 2010 08:34 AM
2010 HIN/NOPI Supershow Tour – Boston area 7/2-3 and New York area 7/24-25 mcwheels New York & New England Region 0 Jun 7th, 2010 03:09 PM
mini-MINI caravan from Boston area to Area 51 snek New York & New England Region 39 Jun 14th, 2007 01:15 PM
Cooper S rain water leak from hatch area Westy First Generation Faults & Fixes 3 Apr 3rd, 2006 02:01 PM
