| Stupid I know - but how do I disconnect the battery I cannot hear my cd's playing, although I know they are playing as the track numbers are coming up on the screen, and the radio is working fine. I have been advised to reconnect the battery for a few hours, and then reconnect it again, as this should solve the problem. Apparently the cd player should reset itself? Problem is I have never disconnected a battery before. ( I guess I should say I am a female who doesnt have a clue) !!!!! I have opened and closed the bonnet in defeat. Any advice in the simplest of terms would be great. Thanks Lynn |
| Here goes....!!!! Pop the bonnet.... the battery is towards the back of the engine bay on the right hand side under a black plastic box. You'll see thick red wires running into it. there are 3 plastic clips to release, then lift the lid off the top. You'll be able to see the battery and terminals on top of it. With a size 10 spanner or socket, loosten the nut on top of the terminal ( no need to take it fully off ) then pull the terminal from the battery. Remove the + first to prevent sparking 3bars |
| Thanks so much !! Just want to say thank you to everyone for their help (especially to 3bars for your step by step guide). I will give it a try at the weekend,as by the time I get in from work it is too dark to see what I am doing. I will let you know how I get on. Fingers crossed !! |
| Alarm keeps going off - Ive had to disconnect battery! | cokey | First Generation Faults & Fixes | 17 | Jan 30th, 2011 12:15 PM |
| Icelink Plus not working after battery disconnect | BlueMax | First Generation Interior & Ice | 4 | Jul 5th, 2007 11:55 AM |
| Should I disconnect Battery or No ? | sa3dos | Maintenance & MINI Care | 14 | Dec 22nd, 2005 10:47 PM |
| Battery disconnect | Adel | General Discussion | 7 | Aug 28th, 2003 08:04 PM |
| Battery Disconnect in Accidents | Ken2002S | General Discussion | 4 | Oct 17th, 2002 06:46 PM |
