Normal unleaded vs premium unleaded - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2012, 08:08 AM
harvey94's Avatar
Local Time: 08:45 PM
Male
Hi,
Sorry if this has been asked before but I just wondered if there was any benefit of using premium unleaded rather than normal unleaded. Please understand this is not for performance gain just more for is it better for the engine and also more mpg would be nice .
I have read the manual of my mini one and it does say it can accept 2 types of fuel , so at the pump there is normal 95 unleaded and premium 97
Thanks for the time!
Old Jan 28th, 2012, 04:36 PM
Online
Which? magazine did some pretty thorough testing on this and found that forced induction engines (so Cooper S and JCW) benefit from super unleaded, for either power or economy, but that it did not do anything for naturally aspirated engines (First, One, Cooper).
So for you One, don't bother. I put ten tanks of super through my justa Cooper and didn't measure any mpg benefit. Whether the engine feels stronger is, I think, largely a matter of your beliefs - if you think super fuel is going to be better, you'll convince yourself that it is, and vice versa. I don't think many of us can detect anything less than a 10% power increase just by seat-of-pants measurement.
Which? also tested super diesel, though in just one car, and found it performed worse than regular diesel!
Old Jan 28th, 2012, 04:57 PM
harvey94's Avatar
Male
Hi,
Many thanks for the reply! regular will do just fine for me then!
Old Jan 29th, 2012, 07:30 PM
Local Time: 07:45 PM
There is another benefit to so called "super fuels". They have detergents and injector cleaners in them as well. However, it is cheaper to buy Redex or other injector cleaners than constantly fill with the super stuff.
Old Jan 30th, 2012, 11:27 AM
harvey94's Avatar
Male
I have heard about the likes of injector cleaners but never actually used any, is it a good idea to use them from time to time? i hear mixed opinions and some say can do more damage than good?
Old Jan 30th, 2012, 09:06 PM
I use a bottle (2 fill ups) of REDEX every time I do a service - I very much doubt it would do more harm than good. What can happen though is, if you're a cheapskate like me using Tesco fuel, that some of the gunk that put in cheaper fuel can gum up your injectors - so I sport £3.99 every 12,000ish to keep things ship-shape.
I suspect the horror stories come from those that put it in every fill up expecting to get some "wonder power gain" - that said people who look for and expect such gains normally thrash their cars within an inch of their life anyway!
Gaz
Old Jan 31st, 2012, 06:14 AM
harvey94's Avatar
Male
Gaz
Hi,
What would you sudjest for me? Our mini is a late 2002 52 plate with 80.000 on the clock, I always look after my cars with regular service and general maintenance, obviously I can't do anything about previous owners. Unfortunately although the car has every service stamp the last couple were not done at a reputable garage and with some checking was obvious that simple air filters and such had not been changed! Well I have now done everything from spark plugs to gearbox oil and she runs lovely! Just wondered if I add this could it by chance do more harm than good to a car that has never had it and will just assume has always had cheap fuel!
Thanks!
Old Feb 1st, 2012, 10:46 PM
Harvey
If it was me then I'd run some REDEX through with 2 tanks of gas and then not worry about it again until next oil service. She might be running lovely but your Engine Control Unit "adapts" to any components running slightly worse than best (ie. a slightly blocked injector). Run 2 tanks worth of gas with REDEX (or another reputable injector cleaner) through and that should clean any gunk off of them (if indeed there is any) and you're likely to get some more miles without issue; it's better to do preventative maintenance than wait for the failure (which normally will cost lots more time and money).
But hey, that's just my opinion - the decision is yours...
All the best
Gaz
Old Feb 2nd, 2012, 04:11 PM
harvey94's Avatar
Male
Harvey
All the best
Gaz
Thanks! i will give it a go , is it best to add it before filling then fill or other way around? or does it not really matter , i am just under half a tank and normally dont let it get under a 1/4
Thanks!
Old Feb 2nd, 2012, 06:18 PM
I normally put enough in for a full tank and then top it up - that way you ensure you mix it. That said, normal driving would soon mix it!
Old Feb 2nd, 2012, 06:27 PM
harvey94's Avatar
Male
Superb! Many thanks!
Unleaded V Super Unleaded/Ultimax/Optimax Cooper86 General Discussion 14 Oct 3rd, 2006 05:19 PM
Unleaded or Super-unleaded Billy Smart First Generation MINI Cooper S 15 Jul 8th, 2004 12:22 AM
regular unleaded vs super unleaded sugster First Generation MINI One 26 Dec 18th, 2002 04:33 PM
Unleaded (premium recommended) mini-is-4-me Maintenance & MINI Care 1 Aug 27th, 2002 01:23 PM
Premium Unleaded Basil First Generation MINI Cooper S 5 Mar 3rd, 2002 10:12 AM
