Cruise control - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 30th, 2012, 06:23 PM
Local Time: 07:46 PM
DIY Cruise control
Hi !
I have a simple question:
Is clutch switch in R50 the same as brake switch ?
Also what the the best place to get the wiring for cruise control ? BMW or mini dealership, any other company that can supply it ?
Last question what is the best place to have you mini program in london ( north or west
Old Jan 31st, 2012, 03:15 PM
Local Time: 08:46 PM
Hi
I take it this is for retrofit cruise control?
i installed this to my car at the weekend using a brake light switch, for the clutch switch.
i got the wiring loom from my local BMW dealer.
i still need to get it coded but fingers crossed
Old Feb 2nd, 2012, 03:34 AM
The R50 may have two clutch switches. One is a simple prox switch which sits adjacent to the top of the pedal. It is not the same as the Brake prox switch as the brake switch has two switched outputs, one for the brake lights, whereas the clutch prox switch only has one switched output. The clutch may also have a switch which is a plunger type switch mounted on the clutch master cylinder. This is used to detect clutch position when starting the car.(prevents starting when in gear) There is a wiring diagram in the Bentley Publishers Mini Service manual but you can also see it here at bmw-planet.com/diagrams/release/en/r50/index.htm
Cruise Control DAVEC104 Second Generation Interior & Ice 1 Apr 26th, 2010 07:40 PM
How do you get cruise control? loopyanna General Discussion 18 Jul 2nd, 2008 08:49 PM
CVT using Cruise Control nonsequitur First Generation CVT & Automatic 22 Jan 29th, 2005 06:27 PM
Can you get cruise control....... Phrozen General Discussion 7 Oct 31st, 2003 04:54 PM
Cruise Control on MCS Blacksack First Generation Faults & Fixes 15 May 23rd, 2003 03:17 AM
