Map or maf sensor - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 9th, 2012, 05:28 PM
Local Time: 04:09 AM
Map or maf sensor
Does a mini Cooper s r53 have a maf sensor or map sensors
I've read that it's map?
If so exactly where abouts is it located, and can they be cleaned??
Old Sep 9th, 2012, 06:41 PM
I think the map is at the throttlebody can be cleaned with the map cleaner or brake cleaner.
I am only going by what iv read
Good luck
Old Oct 6th, 2012, 06:00 AM
Local Time: 05:09 AM
Can anyone link a photo DIY for dissasembly to access the MAP for cleaning on a 2006 Cooper S please? It's pretty tight in there, does the inter cooler need to come off?
Old Oct 6th, 2012, 07:17 AM
There are two Manifold Air Pressure (MAP) sensors. One is located on the front of the inlet manifold, on the right hand side as you stand in front of the engine, this measures pressure after the supercharger. The other is located just above the thermostat housing, it has a pipe connected to it which plugs into the plastic inlet to the supercharger, this measures pressure before the supercharger.
The first one will be easy to remove, you may have to remove the intercooler for access. The second one is trickier, I've not removed one of these before, but you may need to unplug the pipe from the plastic intake pipe - which means moving the front end module forward, alternatively you may be able to remove it from it's bracket and remove the pipe at the sensor, I'm not sure which. Perhaps someone else can fill in the gap here?
Old Oct 6th, 2012, 09:04 PM
United Kingdom Female
This forum is so useful.
Sorry off subject any good mappers/ tunning companies in west London? And has anyone got coilovers on cooper s r56
Old Oct 7th, 2012, 03:49 PM
Why not search for a post about those subjects and add to those threads or start new threads. It makes it much easier for future visitors to the site.
Useful!
