Mini cooper s r53 37,000 using oil is this normal - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 25th, 2012, 01:25 PM
Local Time: 02:29 AM
Hi
First post on here just wanting a bit of adivice I have bought an r53 cooper s in hyper blue from BMW mini dealer . Its done 37,000 miles and was serviced by them when I bought it . I decided to check my oil a month after purchasing it to find it was just registering on the dip stick and I mean just . I rang them to ask if the mechanic forgot to fill it up . I was asked how many miles I had done I told them about 1500 miles I was informed that it is normal for the r53 engine to burn this amount of oil .
Is this normal to burn 1ltr of oil every 1500-2000 miles ?? are they having a laugh .
Should I be taking it back ??
By the way no blue smoke out the back exhaust it is a bit sooty no water in the oil and no oil leaks I am aware of , it also runs smooth .
leedslad
Old Nov 25th, 2012, 01:41 PM
Dermottdog's Avatar
My old R56 MCS was using oil too. I learnt to accept it. Dealer said it was normal for my turbo engine to 'use ' a litre per 1K miles.
There are many posts on here regarding oil usage, although most of it seems to be my model and not yours.
I used to check my oil level on a weekly basis (and still do).
You need to make your dealer aware that you want it recorded on their system.
Old Nov 25th, 2012, 03:04 PM
Local Time: 09:29 PM
United States Male
One data point on oil consumption is not enough, unless it was YOU who last checked it. That mechanic isn't going to tell you he goofed it. Also, did you check on a very level plane, and allow 5 mins for oil to drain back into the sump? I always change my own oil, because then I know it was done right. I pre-fill the filter to avoid a wrong reading there, and still double check after running a minute or so.
Any new-ish engine using a litre of oil per 1000 miles doesn't sound normal, or acceptable to me. You would need to carry an oil bottle everywhere..!
Old Nov 25th, 2012, 04:19 PM
The driver should be checking the engine oil level weekly anyway and keeping it topped up, some seem to think it goes between services without the need to lift the bonnet, this could be 19000 miles or a whole year.
A brand new engine can use more oil until its bedded in, thats why you have the running in period, run it in carefully and it will last and the oil consumption should then reduce, not running it in and using the full performance from the word go you risk ending up with an engine that never beds in properly. Unless youve had the car from new you never know how the car was treated during its first couple of thousand miles.
Old Nov 25th, 2012, 07:14 PM
Topped up now
Right I have topped the oil up it has taken just under a litre so I wil see how I go .
How much oil should the average r53 mini be using ? I know all use different amounts but is there an average .
From reading other threads on this it appears I am doing well if im getting 2K between a litre of oil .
Thanks for your replys
Old Nov 25th, 2012, 08:31 PM
Dermottdog's Avatar
It varies. I drove to Devon and back. My oil was topped up to the full mark before I left London/Kent. It was quite a bit down when I checked it when I got back a week later. I carried a litre of oil in the boot at all times. Some weeks were worse than others. With my new car, I am not using so much and therefore keep the oil in the garage. As others have said, check it on a weekly basis and email your dealer to document the oil usage. You then have a copy if it starts to become ridiculously thirsty for oil.
Old Nov 25th, 2012, 09:00 PM
Did you complain ? mine is still under warranty only had it couple of months so far I havnt had much luck power steering failed then cam tensioner went on me sounded worse than it was .
Dont know to go back and create with them . i love the car and I hate to moan just want it to run right and I know deep down I shouldnt be having to be topping it up this much
Im off back !!
Old Nov 26th, 2012, 07:52 PM
England Love hate
Im off back !!
I've got a Countryman & a MCS. Love to drive the cars but **** poor reliability ruins it. Wont be purchasing another Mini & will for ever steer people away from a manufacturer who sells cars with intrinsic faults that they loath to repair unless your paying for it.
Love my cars, hate my cars, must have been women in a past life
Old Feb 4th, 2013, 08:10 PM
RickB's Avatar
Local Time: 01:29 AM
United States View RickB's Dark Silver & Black 1st Gen MINI Cooper S Profile
I've had my R53 since new, September '02, and I'm nearing 90k miles on the odo. Initially, I saw no signs of consumption between oil changes, but now I probably add a half-liter per year.
Am I dreaming, or was the recommended oil change interval originally 25k miles? I saw that it was recently changed, for newer MINIs, to 10k, but swear I went over two years without an oil change (I know, I know . . .), and even then, the service light wasn't on yet.
"I'll shoot for the queen, and you for, well, whomever."
Old Feb 4th, 2013, 09:28 PM
mine has lost nearly all its oil in about a month but pretty sure its a leak
once its sorted i will be keeping an eye on it.
will also be trying some oil leak stop to see if it helps.
Old Feb 4th, 2013, 09:40 PM
We have two MCS's both from new one a convertible the other an All4 Countryman auto. Only used one litre of oil from new, the Countryman has covered 5,500 miles and is 6 months old the convertible is 10 months old and 2,500 miles covered. Both cars were driven carefully as per the user manual.
Sent from AutoGuide.com App
Old Feb 4th, 2013, 10:26 PM
Caveman's Avatar
Local Time: 03:29 AM
Initial Oil Service for an R53 was at approximately 10K, then at approximately 15K intervals. I think service intervals are even longer for the R56.
