Battery Charging on R56 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 19th, 2013, 02:32 PM
Local Time: 05:38 PM
I am wondering if anyone has any ideas on how to connect the Ctek battery charger to the mini Battery easily. I don't really fancy having to keep opening up the black cover on the battery everytime i want to charge. I only use the R56 once in a blue moon as its a bit of a summer car kept for having fun days out in.
Old Jan 19th, 2013, 04:25 PM
Have you bought the Ctek yet? If not buy an optimate 4 from Amazon. It has a short lead that you can connect to the battery using an eye connector on each terminal, so it is connected all the time. On the other end is a connector that plugs into the lead from the Optimate charger, so all you have to do is unplug it from the short lead when you want to go for a drive. There is a little rubber cover to go over the end of the plug when not in use.
You have to remember to unplug it though!!!! I have forgotten a few times and dragged it out of the garage still connected. But it has just unplugged itself without doing any damage.
My 7 year old JCW still has the original battery, it is a summer car and has been on an Optimate all its life.
The Optimate 4 does all sorts of battery checks, like stopping charging for 30 mins to make sure the battery is holding its charge ok.
It's about £50.00 But a lot cheaper than replacing the battery.
Old Jan 19th, 2013, 04:58 PM
Haven't bought it yet. I will definitely take a look at that product. Same price as Ctek charger. Ctek do the snap in system too but they charge another £8 for it so the Optimate is cheaper in long run.
Old Jan 19th, 2013, 07:06 PM
I bought it from Amazon for £52.95 with free delivery, prompt delivery as well. Very reliable and apparently very cheaper to run, as far as the electric bills are concerned.
My original Optimate that I use on another car has been dragged down the road by accident but still works fine!
Old Jan 20th, 2013, 10:17 AM
Local Time: 06:38 PM
I got a CTek and bought the extra connector (snap-in thing that lets you permanently fix one end to battery and simply plug in when needed) and then found it came with one - worth double checking before you buy.
